Re-activating my HiRail line (20-year hibernation) and adding a double-track 2-rail scale 0 line 8" above it.
I have all the engines, freight, passenger, cabeese I’ll ever need and then some, but what I don’t have is a wrecking crane.
Where does one find an old 0 scale wrecking crane any more?
Old, as I have ScaleCraft, All-Nation, Pearce, General Models, not looking for plastic (actually, have…NO plastic engines or rolling stock, come to think of it).
I would definitely post this question on the CTT side of the Forum. That being said, I think you could utilize the Lionel 2460 six wheel big hook - at least for a stand in.
Postwar rarely is close. Some wag in some publication, oh, Model Railroadersomethingorother, back in the late 40’s early 50’s, measured a bunch of the Lionel postwar stuff, calculated it was about 1:52 or 1:53.
Compared to the generally 1:48 for 0 and Proto48, well that’s 10%. I have three 0 flatcars on my HiRail pike, and you can tell. Nothing else would work.
It’s as bad as running 027 boxcars behind a big 031 steamer.
It’s all about perspective, and sometimes you can get away with it, sometimes not.
I think the Lionel cranes are about 1/2 the size of 0…and I’ve only seen a handful of 0 2-rail crane cars on 60 years.
3-rail O has come a LOOOONNNGGG way since the post war days of sub scale toys. Lionel and MTH have both made pretty good scale 250 ton cranes that are easy to 2-rail. IIRC, MTH’s 250 ton crane comes Kaddee mounting pads.
Lionel has even done a command control operating crane. The Lionel features two hooks, boom elevation, rotation, couplers, flood lights, and outriggers that are all independently operated via remote control. It, might plastic, but it’s a pretty darn good scale model, and it works. You can also purchase a separate crane tender that contains a sound system that syncs to the operation of the crane.
