1/2 inch or 3/4 inch plywood?
I think the specs should reflect the design.
L girder construction isn’t needed on a true cookie cutter with narrow risers because the flat top will add stability over a shorter span. If you’re talking open grid construction, L girders are needed to prevent the sideways sway that’s absent when fastening to a plywood top.
For the record, my cookie cutter is constructed of 1/2" plywood, 1x4 and 1x3 pine on 12-16" centers, and 10" span on risers. My goal was to keep it durable and light weight, as it’s intended to be mobile. I could have gone 3/8" plywood, but the extra rigidity of 1/2" was worth the weight in terms of scenery support. It is very strong, and I think I made a good choice of materials for what I wanted.
I also think that going with shorter centers rather than thicker plywood should be looked at, providing you use quality lumber. 3/4" plywood will warp too, over time. Your frame is what dictates the long term quality of what you build.
I can see your point. I would probably take this on a section by section basis and build what is appropriate. I’ve been known to mix and match on occasion.
Bob K.:
Just to clarify – I was quoting Clark and asking him the same question about L-Girder BW. Sometimes the “Quote” button (or maybe me) doesn’t work right and can become confusing! As it did in my previous post.
I guess I’d better jump back in here. I did mean “never use L-Girder benchwork”. It has no inherent strength and is not portable. [Yes, you can, and probably will, argue that forever.] The platforms and support systems we use are taken from my many years as a Broadway Stage Designer. Every stage set is built using some form of this system because it has to break apart invisibly, go into and out of trucks and then go back together again just as invisibly without falling apart.
The system consists of a unitized platform that may be square or may have many angles to mate with other sections (just like a layout). It is traditionally a box frame with 1x6 (read that as 3/4" x 5-3/4") dimensional lumber or plywood. Everything is glued and nailed (and blocked in the corners when necessary). We actually cut our 3/4" plywood framing to 5-1/4" so as to acheive a six inch thick platform employing a 1/2" plywood top. The result is a layout section that three men can stand on (and do). This platform is generally framed with spreaders every sixteen inches to two feet depending on the weight the unit is to carry. Our base frame is also right from the theater and consists of 1" x 2-1/2" 3/4" plywood framed on edge and faced on the front with T-111 decorative plywood. Each base unit is 32" high giving a typical layout height of 40" when you add two inches of styrofoam to the plywood platform. It also provides a completely finished skirting for the layout complete with access doors. On the rear of the layout (assuming that it’s not an island-style layout where there is no “back”), the inner open frames are solidified with triangular 1/4" ply “corner blocks” approximately nine inches on a side and cut on the diagonal of the ply for greater strength and then screwed or bolted to the nex
The system consists of a unitized platform that may be square or may have many angles to mate with other sections (just like a layout). It is traditionally a box frame with 1x6 (read that as 3/4" x 5-3/4") dimensional lumber or plywood.<<
If you use this type of box/platform construction how do you add risers to achieve different levels of track?
With a plywood platform you can place them exactly where they need to go, (as opposed to using the nearest joist.) I do grades by cutting risers of incremental height, calculating the distance of the rise, dividing by the number of risers and spacing accordingly. I pop them in with a nail-gun and the grade is very smooth and even without a lot of time or effort.
I see how this can have an advantage. Especially if foam risers etc are used. The only problem I see is that any elevated track having switch machines would have very awkward access if at all. Then provisions for some access to replacement or adjustment should be made.
With foam you would have a problem. With the wood risers and cookie cutters, you only have the risers at most every foot or so. You can work around a switch machine easily enough. I defiinately leave openings for all kinds of access–to tunnels, turnouts, etc.
It is simply false to assert that L-girder benchwork is neither strong nor portable. Please elaborate for us so that we can understand why you make that claim. Although, it will be most difficult for me to reconcile what you say with what I use for a layout currently. I can, and have, walked, crawled, knelt, and jostled all over my twin 8’ parallel spans and have not had a single indication that they are “inherently” weak.
I hate to be a bore but I assume that you are using 3/4" wood blocks for risers and that you are popping in the nails from beneath the platform? Do you also slope the top edge of the riser to match the grade of the track? Do you use plywood or solid wood as the bridge between risers?
Second question: How do you mark reply text in a yellow box to indicate the message you are replying to?
Click on the “quote” icon
Risers on plywood “platform”.
On my layout, I used the cookie cutter method for construction. I first built a “platform” of 3/4" plywood on 2X4’s, basically built as a wall but horizontal. Both the platform and the risers were built out of 3/4" plywood. I did this both for strength and the resulting smoothness I’d get on the vertical transitions for the risers. Lets face it, you simply cannot do anything quickly using 3/4" plywood, which is desired for a vertical transition. As some commented it may be overkill, but so far I haven’t regretted it. It also makes it so that if you cut a riser to the wrong height, you find out about it immediately when the other risers don’t fit.
Second, I laid out the design full-sized using plain white paper covering the layout. This laid out both the trackage as well as the required widths of the elevated track sections.
I then used this full-sized drawing, cut into templates, to cut the elevated track sections, along the longest pieces of plywood available. I used the same templates to cut the 1" blue foam to overlay the elevated track sections. This kept all of the really messy cutting in the garage. The blue foam was glued to the plywood.
The risers I cut out of scrap 2X4’s, finish nailed from the top and bottom, and glued. Typical spacing was 16" to 18". Where I put a switch machine on the elevated track (3 of them) I cut a nice sized access hole through the platform to get to it. On one I had to shift the riser off to one side and adjust it’s height accordingly.
The heavy plywood does make it a bit tougher to cut in the slots for a tortoise switch machine, but it’s not that much harder.
To install a tortoise, use 0.30 piano wire, available from your local piano repair parts store. I’ve got a guy that will sell it to me for $0.10 per foot, in 10
To each his own, Selector! I know L-Girder has beeen around for eons, but that makes it neither strong nor portable. John Allen thought it was the way to build too, and his layout was lost when an attempt was made to move it after his death. If you had been asked to repair as many L-Girder and plaster layouts as I have, you’d understand why I build the way I build. The bottom line, though, is that if L-Girder works for you that’s all that matters. This is a hobby, after all.
As regards turnout installation, we’ve standardized on the PECO system which places the switch machine under the turnout at the points and gives absolute electrical contact at the points. If you provide slip track connectors at the heel of the turnout any time you need to service it all you have to do is slip the connectors and lift it out for service.
Happy Railroading,
clarke@dunhamstudios.com
The L-girders themselves are actually very strong. The joist installation on top of the girders is what’s weak.
An L-girder is basically a built-up 90-degree angle. The way we use them for benchwork is not very efficient from a load-bearing ability point-of-view. As they’re arranged, adding load makes the beam tend to twist into it’s minimum strength orientation - something a bit less than 90 degrees off it’s usual orientation of large flange vertical (that min-strength angle depends mainly on the relative widths of the flanges and strength of each of the flanges). Making the L-grider into a T-girder would significantly reduce that tendancy,and make the entire girder much more stable. The reason the L-girders don’t twist and bend is because they’re so lightly loaded in our application (even a couple hundred pounds of layout across an eight-foot span is light loading compared to what the girder can actually handle) - a result of needing to effectively eliminate deflection in the beams).
As I said above, the joist installation is what’s weak. Screws are tension fasteners (they’re designed to take a tension load along the axis of the screw). They’re generally very weak in shear (loading at 90-degrees to the axis of the screw - sliding two blocks along their mating surfaces is a shear action) and bending (just what it sound like - bending the screw), unless they’re specially designed to handle those forces. Drywall screws, which most of us use, are tension screws.
So here we go, laying a joist on edge across our L-girders, then screwing through the top flange of the girder and into the joist. If we put a heavy load on the center of the joist, it will try to twist into its minimum-strength orientation (lie down flat on the girder), and what is resisting this tendancy is bending stress in the screws, which of course were not designed for that. So the screws will break pretty early on in the loading of the joist, and the joist will
Mark, thanks for that. I have no engineering background, but even I could see a problem with the arrangement you described, and which I saw when I was researching L-girder and cross-beams atop them. It seemed wacky, to my way of thinking, so I placed all my joists between the parallel L-girders, even some that were diagonal for riser orientation. I can’t help but have much more confidence in that configuration. For one thing, it reduces all that extra height from the joists atop the girders, but it creates a much stronger box-shape, preventing the girders from wanting to reorient themselves under load as you have aptly described. I cannot claim that my way is hugely superior, but it is/must be substantially so.
The gentleman with whom I was just discussing the matter relates how John Allen’s benchwork self-destructed upon and attempt to move it. I don’t doubt this story at all, why would I, but could it not simply be that the late great J. Allen did not build his L-girder bench in a sound way in the first place? If he made some false assumptions about their best use, then it is no wonder the result this gentleman describes.
From what I recall reading old MRs and Model Railroading with John Allen, most of Allen’s benchwork was finished before Wescott developed L-girder benchwork (please let’s not argue over who developed L-girder benchwork - from what I read Westcott was given credit for it - or maybe I remember it wrong). From looking at his construction photos in the book, most of his benchwork was basically built to his basement topography, and took most of its strength from the walls and floor. When the section being “rescued” was lifted away, the benchwork wasn’t stable on its own, and collapsed when moved (a tragic loss, IMO).
The big advantages of L-girder as Westcott described it was that 1) no precision cuts were needed, since joints don’t butt together, and 2) easy free-form layout edges, since the joist ends could be a long as desired, rather than butt against side girders as in grid construction. One of the big drawbacks, of course, is the total depth of the benchwork becomes significant.
This is classic L-girder construction:
Selector - it sounds like you have adopted something of a hybrid between classic L-girder and grid benchwork (grid benchwork, by the way, is significantly more stable than L-girder, though not quite as strong - but way more than ample for model railroading in any case). I’m curious - what does the inclusion of L-girders in a grid type construction gain for you? There is some enhanced rigidity to the structure because of the L-girder in place of flat girders, but is there something else as well that I’m not seeing? I’d like to know, since I’ll need to minimize the thickness of my top deck benchwork so was planning on using grid construction there.
I just wanted a longish span of two parallel girders under my yard, which fits, I am embarrassed to admit, on one sheet of 5/8" ply. I didn’t want a set of supporting legs midships since the plan, according to She, was for storage under the layout, and too many legs would make it awkward to store the large 130 liter Rubber Maid bins that we use for our 4.7 tons of Christmas “stuff”. So, I wanted strength, but not the additional height that the usual L-girder and joists atop them would take. If you can see well enough by the photo below, this is what I came up with. As I said, where it seemed prudent to include a diagonal “joist”, I cut it at placed it. These were also desired for the extra rigidity in a box frame, of which the L-girdes comprised two long sides for each of the four modules.
First image is the plywood yard. Now that it is bolted to two modules on either end of it, each at right angles, I could get rid of the braces and legs and probably still have plenty of strength…maybe I should defer to you on that…[%-)]
This next image was taken as I was building spline roadbed. You can see how it all went together, but the risers give the…um, rise…and the joists are nestled out of the way.
What else do I get out of this…maybe nothing…I just felt that this would work, and be strong enough to withstand disassembly. It will take some unbolting, some cutting of plaster terraform at the seams, and cutting some wire. The rest will be horse work getting each module upstairs after the legs are removed. Maybe I am dreaming. Wouldn’t be the first I’m sure.
I adapted the 1x6 simple frame construction that was in use at Dunham Studios when I worked there (the best job in the world! Thanks Clarke), except I used 1x4s as my around the wall layout’s max depth is 24" except for the yards where I did use 1x6. Everything was topped with 1/2" CDX ply and then with 2’ foam. All joints were glued (carpenters yellow glue) and screwed. The foam was attached with regular liquid nails and held down with 3" drywall screws until dry afterwhich the screws were removed and reused. I believe they use a latex contact cement to attach the foam at Clarke’s now, which I would too, but I’m done with that part. The whole thing has been extremely stable for the past 7 or 8 years.
Selector,
I hate to break this to you, but what you are showing me is a box-frame construction to which you’ve added horizontal pieces (which add a little stability). Not that this is bad, but you are arguing apples vs apples.
Edit: I missed Mark B.'s last post. He picked-up on it before I did.
Bill, As already suggested, 3/8" for short spans or 1/2" for slightly longer spans are adequate EXCEPT… If you can ever see the need to be on it, you will really be glad you chose 3/4". For normal use it will be bullet proof stable. but someday you may need to put a knee or a foot on it, to do something awkward, and going through it would probably ruin your day. jc5729
