1225 Polar Express
Does anybody have the part number for the smoke element for the Lionel 1225 Polar Express?
http://www.lionel.com/CustomerService/ReplacementParts/index.cfm?doAction=productPartFilter&number=6208649001&productID=ff5c7516-7c7a-4441-9eb8-7468eb82d2fa
@Boxcar Bill - do you know if these smoke units would be better than the original units put in the PE engine back in 2004?
If you are running conventional and like smoke, and lots of it, install this resistor 691-RS18-OHM. Be advised if you run command you will have fire coming out the stack.
Bill
@Bill … I’m finding Lionel part # 691RESC018 … would this be it?
I’m using conventional mode and want my PE engine to smoke like crazy!
Thank you in advance.
The 691RESC018 is ceramic coated, the 691RS18OHM is a wire wound. Just drop the - between numbers.
Bill
Thanks, Bill. That is exactly what I need.
Jim
