2 LIONEL SC-2 SWITCH CONTROLLER
HOW DO I WIRE 2 LIONEL SC-2 SWITCH CONTROLLER TOGETHER SO I CAN USE 8 SWITCHES [#welcome]
SC-2 Instructions
Rob
All you do is hook your switches up on the second unit and use consecutive numbers such as if the first unit ends in 6 the first on the next unit will be 7. Page # 13 of the instruction manual explains it I believe.
I have three SC-2 controllers and when you get them from the factory they are preset for X number of switches and Y number of accessories. You can program the SC-2 to handle all switches or all accessories. Since I have two SC-2s running 10 switches, the one controller was programmed tor switches 1-6 and the other 7-13. The manual explains how to program.
A hint on using the SC-2: You might need to experiment with location and orientation of the SC-2 for it to pick up a good signal from your track and wiring. There is an antenna inside.
As long as the SC-2’s are near the Command Base, there should be no signal issue. They get their commands from the Command Base.
Two of my three SC-2 are over 43" away from the command base. In fact the one is about 48" I wonder why they work so well switching those switches and turning on the lights, sounds and animated accessories on the layout. [?] I must of wired them wrong.
As a wild and crazy guy, I’m going to put my next SC-2 over ten feet away form the command base, bricks and TPC 300.[wow]
You missed the point. Your SC-2’s are fine - I would consider them all near the CB, even the radical(not) 10’ separation.
They get their commands from the Command Base, not the track and wiring. They could be ten miles from the bricks, wiring, and TPC and still work fine.
I disconnected the CB from the track but still connected to the power, and my SC-2 didn’t work. The SC-2 was less than ten miles away from the bricks, wiring and TPC. Must have done something wrong since the CB should have still made them work without being connected to the track. [oops] Connected the CB back to the track and miracles of miracles, my SC-2 works again. Must be magic. [yeah]
Those fools at Lionel even got it wrong in their manual:[:-^]
The SC-2 has a built-in antenna to receive signals from the TrainMaster Command Base. Place the SC-2 anywhere near
Buckeye, I’ve seen your layout and run trains on it with the SC-2’s. Seems to work great. I guess you and Roy M don’t know what you are talking about. [;)] BTW: it does get its signal from the track [as antenna] like TMCC. [:-^]
No reason it shouldn’t. It seems he’s following all the rules. I wouldn’t expect SC-2’s, SC-1’s, ASC’s, OTC’s, or any TMCC equipment to work at all without the CB being connected to the layout.
