Hello to all.
I am pleased to announce that the 2035 arrived Friday. As I first looked at all the pices and shnibbles of K-4 that was left, I knew it would need a good teardown, and ELC (extreme loving care).[;)]
As I first inpected it, I found it was quite (an understatement) dirty. [:0] I first disconnected and desoldered all of the wires, and then took off the brushplate and bearing plate, which held the armature.
So then I took my handy dandy electric motor cleaner, and layed on the spray. I noticed a puddle of BLACK liquid(the contact cleaner with all the junk in it) accumulating on my wash bin. I also cleaned and polished the commutator.
After all of the cleaning was done, I cleaned and reconnected the E-unit. I also lubed all gears and bearings. Then I tested the motor on my layout.The complete rewire was succesful, the eunit cycled, and the motor cycled also properly. But when I started to get going, the motor ( probably the gears) growled fiecly. I had to turn the reostat to full to get it to a good cruising speed.
