2225 gal Bromine-4000 gal 2 dome motor oil tankers
https://www.flickr.com/photos_user.gne?rb=1&path=&nsid=53243414%40N00&page=&details=1
I’ve taken new photos of these cars I scratched a while back. The Bromine car was done using an article from MR. The 2 dome was built using plans from RMC. Thanks for looking.
Regards, Bobby
As always Bobby, your cars are works of art!
Dave
Bobby all ways great models you have.
And when are you going to mass produce the two dome one, like them alot.
Guys, thank you all for your kind comments. The two dome was built in brass by OMI several years ago and can be found on eBay once and a while. Thanks again, Bobby
Bobby:
I have to ask how you get the faint rust effects on the upper surfaces of the tankers and the slightly more visible rust stains below the stanchions (sp?)?
Thanks
Dave
Top of the line work, as always!
Dave, I used Floquil box car red for the streaks and Brandon powders for the top. Regards, Bobby
Ray, thank you very much. Regards, Bobby
Neat little car. What is bromine, what’s it used for?
Southgate:
Many uses I’m sure, but I use it to keep my hot tub clear.
Dave
Bromo seltzer for stomach upset, until they found bromine was toxic and ethylene bromide back when gas had lead in it. Now according to wiki it is used as a fire retardant in various plastics. There is a Bromo Seltzer tower in Baltimore and you can buy an HO model of it. http://www.prototypicalmodeltrains.com/product/CMR-Bromo%20Seltzer%20Tower
Try this for starters: https://en.wikipedia.org/wiki/Bromine. Bromine is a fascinating element related to chlorine and has many uses.
Joe
Meticulous craftsmanship as always Bobby.
I remember that MR article on the bromine tank car. The material is so incredibly dense that the cars look mismatched, as if a TT or N scale tank was somehow mated to an HO frame. There are some good shots of bromine tank cars in the Morning Sun color book on tank cars with center sills. There was quite a variety of such cars, but all were small – and if I recall the MR article correctly, were too small to be repurposed so bromine was evidently all they were good for.
Dave Nelson
Thank you Dave. There were some larger ones that I think are still in service. They have 100T trucks and full length top walkways with end ladders. Google bromine RR tank cars to see photos. Regards, Bobby
So this stuff is still used ?
Yes. Yes it is. Regards, Bobby
Thanks.
The above answer was a bit short. Google-uses for bromine, there are many uses. BTW, Bromine weights 28lbs per gal. Regards, Bobby
Does anyone know what issue of MR had the Bromine car article?
Mark
