3" Crossover Clearance: Which Cars are too tall?
Steam era. Mid 1940s. Besides crane cars, what other rolling stock or locomotives will be too tall for 3" clearance passing under crossover tracks? I can’t go over 3" or my grades will be too steep. Can’t dip the lower track, here, either. So it’s nice to know what I’ll have to do without. There are specific industries cars, like steel, mining, etc. that may present some height limitations that I’m not savvy to… Guess I’ll have to keep my flat car loads low. Thanks.
if you mean you have 3 inches above the top of the rail to the lowest point of the overhead then you have a scale 21’-9" of clearance. i don’t believe there was any equipment in that era that tall. much later when the tri-level auto racks came along 19’ was the tallest i ever saw.
grizlump
I think he might be talking about 3" railhead-to-railhead, considering the design on which he has based his layout. So the actual clearance would be less once one considers height of the rail, tie thickness, roadbed (if any) and subroadbed.
For a short overhead crossings at 30 to 90 degrees or so to the line below, very thin subroadbed can be used above to help clearances. For long areas of overlap, the challenge is greater. The NMRA gauge is probably adequate for accurately-scaled '50s-era clearances.
There are a few items of model equipment that are not perfectly scaled, particularly in ride height (sometimes resulting in cars being too high over the rails). Some of the worst offenders seem to be older models of intermodal cars with containers and auto carriers (not an issue here) and unusual equipment like MOW cranes or tall flatcar loads, as mentioned. There has been the odd steamer that’s larger than “AAR Plate B”, but they are rare these days, I think.
The only way to know for sure is to check rolling stock that seems higher than normal. Accurately measure the real clearance you end up with and and make up a simple “go/no-go” gauge out of a piece of carboard or styrene mounted on a scrap of plywood with some track. Then check the pieces of equipment that seem “high” before operating.
Byron
Model RR Blog
Layout Design Gallery
Thanks Grizlump and Cuyama. Actually, I’m speaking of bottom track’s rail height to the bottom of the 1/2" ply sub roadbed of the upper cross over’s track. (3") Byron, I have been able to reduce the grade to between 3% and 3.5% with the extra 2 ft. 4" of room length over the original plan’s length. (and extra 2’ 4"). I’ll know the grade for sure once I screw everything down and tighten things up. (I’m thinking 3.2 or 3.3% is likely as a max. Most of the run will be 1%-2.5% so that worked out better than hoped for.) 4" was going to be too much of a grade for sure. Thanks again for your helpful caveats last year. I guess my MOW crane will have to be confined to the yards. As I said, I couldn’t think of anything else steam era/'40’a to early 50’s that might be too tall but I’ll look through the Walther’s catalog today.
If you have 3" clearance railhead to subroadbed above, obviously you’re in better shape than railhead-to-railhead. Good luck with it.
in case you haven’t figured it out yet, just multiply your actual measurement by 87 (actually 87.1) to convert any dimension to scale inches and then divide by 12 for feet.
3 x 87 = 261 261/12 = 21 with a remainder of 9. hence 21’9".
grizlump
Eastern roads tended to have tighter clearances than western roads, so if you are modeling the Lackawanna, as your signature suggests, you might be able to squeeze it down some more. The Erie had very generous clearances, and the NYC, NH, and PRR tended to be the tightest of all, in order to fit through the tunnels leading in and out of New York City.
About 15’ over the railhead will accomodate lots of 1950, eastern equipment; that scales to 2.07".
An Accurail tri level auto carrier WITH a load of vans on top is 2 and 7/8" tall. A 40’ hi cube box car is about 2 and 5/16" tall. (measured from the rail head.)
Hope that gives you a frame of refference.
Do you need to allow for some additional clearance in case you have to get your hand in the space (to retrieve or re-rail a derailed car? Might be a good buffer to add.
The question was asked about steam era, 1940’s, railroad undeclared.
Looking through my PRR diagram books, I’m finding 13’-6" for passenger equipment, 14’-11" for a Lines West caboose, and 15’-2" for a big auto box car. A 250 ton wrecking crane is 15’-6". The 1940’s was the end of the short car era, so lower away.
15’-6" scales to 2.14" in HO. Add a quarter inch for safety and you get 2.39".
Thanks for the prototypical references, guys. I’m modeling the Pacific Northwest, actually. I’ve lived in Washington State for 35 years now but did grow up on the Erie Lackawanna in N.J. It was hard not to continue to want to model the East but I love the GN, NP, SP&S, Milwaukee Road, Union Pacific, etc. and can go out to prototypical sites for scenicing reference. I’m protolancing (so far) the Black River Junction between Seattle and Tacoma, WA. We’ll see as the layout progresses. It may move further north towards Bellingham and the border with Canada (British Columbia).
