3 Way Turnout Control Wiring Question
Question for the electronic guru’s out there: Would a 3 position, 4 pole rotary switch work in place of a 3 position, 2 pole switch commonly used in this application? I just puchased a 4 pole switch, and was hoping to use it, as I just paid $10 in shipping for a $3 item. @#&^$
Extra poles are just that - unused sets of contacts on the switch. If buying new, one generally specs just the number of poles needed for the application to save money. If using existing stock, a switch with poles equal to or greater than required by the application is the criteria.
Bottom line: yes, use it if it physically fits. Some contacts will go unused.
Fred W
Thanks Fred, that’s what I was hoping to hear.
