I read that Southern Pacific and Cotton Belt, between them had 357 SD45’s, and got along very well with them. I’ve also read that a lot of SD45’s were retired early due to twisting crankshafts. Yet, MRL and WC both seemed to have them around a long time. Were they a good locomotive, or a problem locomotive?
Yeah,that is kind of funny that some roads had problems with their 45’s and others(ATSF,GN,EL,andSP) didn’t seem to have any problems.ATSF and EL bought SD45-2’s and SP bought SD45T-2’s,which would suggest no problems until 1974 or 1975 when they stopped ordering them.BN appeared to have problems with the SD45’s after the 1971 orders,so I wonder if it was due to changes by EMD or improper maintenance by the railroads.I believe I read that several 45 owners changed the fuel rack settings to downrate the units to 3200HP from 3600HP.It was mentioned that the units were fuel hogs,especially idling(this at a time when there was no way the unit could be shut down in cold weather).Maybe someone can shed light on the crankshaft problems.
An SD45 was a finicky beast. The oversized engines and therefore long crankshafts were subject to a lot of problems such as breakage. Also the large radiators were an expensive maintenance problem, even though they are relatively small compared to some modern engines! Most railroads considered them not worth the extra horsepower which reflects in the fact that the SD45-2 wasn’t a phenomonal seller. But roads such as EL made very good use out of them, if not just for extra fuel capacity.
When the WC was first formed, most of the SD45’s it started with were ex BN, with a couple of chopped nose ex NWs thrown in. As the WC started to grow, they bought ex SF 45’s.
The early SD45’s had issues with crankshaft failures, main bearing failures, crankcase weld cracks, and turbo failures. Most of these problems were with the units built between 1966-1968, and part of the cause of them was EMD design issues, and the other part was railroads trying to maintain a high horsepower engine the same way it maintained a GP7. The SD45 was a fuel pig, and had four more cylinders to maintain compared to an SD40. Not traits that endeared themselves to the beancounters during the lean 70’s.
Did ATSF,GN,EL, and SP maintian theirs better than the other railroads that had them? Or, did they get lucky, in that their units were later production models, built after the bugs had been worked out?
Great Northern’s first SD45’s, 400-407, were the first production models,followed by 408-417 in 1967 and 418-426 in 1968.Santa Fe and Southern Pacific both ordered large batches of SD45’s in 1966.Maybe these roads had closer relations with EMD with these early production units and stayed on top of the problems better than the others.Could be that they were more strict in sticking with a maintenance schedule on these as well.
The SP and Cotton Belt (SSW) had no problems with their SD45’s. I remember chasing trains in the Sierra Nevada mountains of California and ususally they ran 8 to 10 SD45’s distributed throughout the train to get them over the mountains. These trains were 100 plus cars long.
By the time the SD45-2 line came out EMD had worked the crankshaft issues out. All of the SD45s which MRL purchased used had been upgraded by their former owners with the newer prime movers. If it did not have the -2 engine inside the carbody, MRL would not purchase the unit.
All of the MRL SD45s in service have been racked back up to 3600 hp with the idea if you are going to burn the fuel you might as well get some work out of it. The fleet provides good service and quite a return to the MRL bottom line.
WC SD45s Going with 6s instead of the upgraded 7 numberings. 6495-6499 Ex BN, only 6497 not rebuilt. 6500-6533 Ex BN, all but 6503,6516,6521,6529 rebuilt to 75XXs. 6550-6556 Ex NW, 7551 and 7554 the only rebuilt units 6578-6599 Ex ATSF, units rebuilt were 7580,7581,7585,7592. 6600-6631 Ex ATSF Only 7606 rebuilt. 6632-6642 Ex MKCX, Only rebuilt units were 7637 & 7638. Alec
The combined Espee/Cotton Belt SD45 fleet rostered 357 numbers built on 356 frames. You can’t believe everything you read. The road liked the SD45s so much that they additionally purchased 10 SDP45s, six SD45Xs and 247 SD45T-2s.
Cotton Belt 8971 was wrecked and burned at Tyler, TEXAS on June 25, 1970. The unit was returned to EMD and rebuilt on the same frame by EMD as Cotton Belt 9156. The 9156 was redelivered to Cotton Belt in June 1971. There were only 356 units: Southern Pacific 317 units and Cotton Belt 39 units. So you have a number range of 357 units 8800-9156, but you only have 356 frames.
If the Montana Rail Link SD45 Diesel-Electric Locomtives are being run with BNSF units in Michigan, what is operating on the MRL? Are the CN SD70’s and GTW GP38’s now on the MRL?
CN could have just taken all the old WC SD45 units and moved them to Livingston, Montana so the Montana Rail Link could have the first option on all of them.
If I remember correctly these SD45’s were subject to the General Rehabilitation and Improvement Program (GRIP), which essentially rebuilt them into SD45-2 spec locomotives. Most of the rebuilds were done in the late 1970’s to middle 1980’s at SP’s Sacramento Locomotive Shops.
That is correct. There was only one SD45 rebuilt in 1979, the rest were rebuilt beginning in 1981. Also, only 167 of the SD45s were rebuilt. As for being brought up to -2 specifications, in the August 1990 roster I have SP actually lists them as SD45-2s. SP did the same with its SD40s (1980-1981) and some of its SD45T-2s (1986-1989, of course these were already -2s). I wonder if SP was going to rebuild its SD45s first but decided to do the SD40s first.
