I’ve been working on this for a while. Talk about steep learning curve. The printer is a Elegoo Mars 2, a resin printer.
I’m having two issues right now. So far, I’ve gotten one semi successful print.
My prints are coming off the supports and attaching to the film in the resin vat. I read on your site that this was caused by too little exposure time. I was running at 2.5 seconds. So downloaded a calibration tool and after testing at 4.5s and 3.5s and 3 seconds I decided on 3 seconds. (Click to enlarge.) I tried to print and the print damage was worse than before.
When you look at the prints you will see what looks like a crack in each of the calibration tests. When I drained the vat, I found the male version of the “cracks” on the film. It looks as if the cured resin stuck and pulled the top layer of the film off the lower layer and then stuck to itself. The “cracks” correspond to the cracks on the face of the prints.
So, whats my next step? Everything I’ve done so far seems to ruin the film.
I have never actually come across anybody mentioning damaging the film. Interesting. Well first I would replace the film and try again. With current settings just to see if it was a damaged or bad film to start with. My other though is the units calibration is off or not working at all same with leveling. So the resin doesn’t get under either all the way. Elegoo Mars has a large forum of its own that might be useful. Most printers have thier own forums.
I was thinking more the calibration it does before it starts printing like finding the start elevation. And locating the film to start. I would definitely contact the elagoo forums. The knowledge base there might have seen this before or have an immediate answer. I would love to know what it is.
Well, I started a chat on the Elegoo site–no response.
I sent an email to technical support–no response.
I joined their users forum–I can read but there is no way to post. There are 100’s of question and the lowest view post was 44 views. Of the first 25 or so posts, most had 0 replies. Maybe 4 did have replies.
I looked on help and they said new topics could be started by clicking buttons on the top or bottom of the page. Help said the moderator could block posts on the individual forums but none of the pages had start thread buttons. And I really looked.
They have a Facebook page, but it more or less chaos and mostyly pictures of printed and painted miniatures.
I hear all the time to use the forums because so big with users. Strange. Ok off the wall idea. Any cubic and phrozen are big too. You could try to post there without mentioning it is an elagoo. You definitely have me wondering. If that is a general potential problem over any platform or machine specific. Worth tracking down an answer.
After poking around I did find an interesting post. Using image search instead of matching words. Some FEP has a protective film on it. Instructions usually hide well this fact. That and that it needs to be removed. Check the FEP for that film. If it is there remove it.
so far I only found two pics that look similar to yours but both had a similar answer to start there.
Yeah, it has that film. I’ll try to remove it. I’ll bet that it was the source of both problems. The resin is not supposed to stick to the FEP, but the film cover probably does.
