Just recently picked up a copy of a program for laying out trackplans etc… Nice little Cad based system called 3rd PlanIt.
Has anyone else used it before or have any opinions, advice, or other sagely words?
Peace.
Coyote
Peace.
Coyote
Very nice drafting program for relatively short money. I think it compares well to AutoCAD (and I’ve used AutoCAD R11-R14), although it’s not nearly as powerful nor does it have the easy use of 3D solid modeling (it can do it, just not like AutoCAD).
I’ve designed my 25’ x 50’ HO layout, a friend’s N scale “door” layout, and it’s being used for my club’s 6300 sq. ft layout. I’ve also used it to design wiring panels, tables, rooms, etc. I am very satisfied with the product.
Over all, I find it much easier to use than AutoCAD, especially for layout design. There is a learning curve, and I highly recommend following the demo lesson step by step. You will be frustrated at first, but then you’ll get to that :“Aha!” stage when you slap your forehead and say, “Now I get it!”
Paul A. Cutler III
Weather Or No Go New Haven
I have version 3.2 and love it. I get quite alot of use out of it, becasue my modeling space seems to change on a weekly basis and I have to redesign to get things to fit. I use the trackplan and cad functions alot but have nver gotten into the thre 3d much. I plan to fix that though.
I wi***he right of way negotions would come to an end so I could get some work done.
James
I seem to do this all the time! No wonder I have this growing flat spot on my forehead!
I picked it up a couple months ago and there’s still a few things I haven’t figured out. But the thing that I found most useful was the 3d rendering. I started out by drawing my space. Walls, stairs, heaters, laundry, etc.
Most recently, I worked out the layout benchwork to find a, floor-plan for lack of a better word, that fits my layout schematic.
Mind you each time I try something new there is a steep learning curve.
The best advice I can give is to join the 3rd Planit Yahoo users group. Then when you have a specific problem, you can get an answer usually within a day or so.
I downloaded the preview copy back in November 2004 and tried it out, then purchased the license a few weeks later. I have designed many variations of my layout since then and I really enjoy the program. It took a little practice at first, but once you get the hang of it the program is really nice.
Here are a few quick steps to get started that I have learned when designing a layout plan with 3rd PlanIT: (Sorry I do not have screen shots at this time to assist in the explanations)
I hope you have better luck with it than I did.
I bought the program several years back and spent 10 straight hours with it. Gave up because my eyes were going buggy staring at the screen for so long.
At the end of that l-o-n-g day I couldn’t even get the dimensions of my basement in precisely.
Sorry I’m not being more specific but it’s been so long now I don’t remember the exact problems and details.
My layout room does not fit any of the descriptions that the program asks you to choose from. My room has two rectangualar areas approx 10ftx 11.5ft and 12.5ft x 14.5ft with a narrow 6ft x 8ft area connecting the two larger areas. I can not figure out how to “draw” it using the template. Help!
Forget the ‘canned’ rooms. Just draw in your actual room from scratch. I really don’t have time right now to type in detailed instructions, but if you will e-mail me with your phone number I will give you a call and talk you through the basics (I am available to talk between about 9 AM to 5:30 PM CST).
Ok, here is one way you can manually build your room layer:
Hope this helps.
Ryan
