44 Tonner?
Any ideas where I can buy a Bachmann 44Tonner online. I’m looking for DC. I realize that this is "old technology ", but, I’m an old guy.
Thanks, Jimmy
Hi Jimmy
I searched eBay for a DC 44 tonner and found this:
http://cgi.ebay.ca/NIB-HO-Bachmann-80044-GE-44-Ton-Switcher-B-O-20-/380267556592?pt=Model_RR_Trains&hash=item5889b66ef0
There are also 3 other 44 tonners for less money but the vendor for two of them says that they have been sitting on a shelf in his hobby store since the 1980’s, and the third is described as “vintage”. Cavet Emptor! The power trucks for the older Bachmann units are no longer available so you had better hope that they are still in good condition. I am going to take a chance on the older ones because I want the power trucks to make critters. Hope ya don’t outbid me![;)]
Dave
Be advised, the older 44 ton are two motor and have motor issues and cracked gear issue. Has happened to me and many others. Ask seller if two motor or one motor. If they do not know how to tell, pass and move on.
You want the one motor. I have two of those.
Hi Rich
Now you have got me thinking! I wanted the older 44’s specifically because of the 2 power trucks so I could make 2 axle critters out of them. With no more replacement parts available I might just reconsider that project. I guess if Bachmann changed the design there must have been a problem.
Dave
I don’t know the specifics of what you need, but Northwest Short Line and other companies sell motors, gears, flywheels, etc. in a variety of sizes. I’d bet you can find something that will work.
I bought one on ebay years ago rather cheap. I decaled and added more parts as NKP 90.
The motor issue I had is a brush holder will hang up and seem like a burnt out motor. Touch the brush holder again and it works fine. From what I have seen, many do not take the shell off the frame and check the motor brushes.
You could check with Dave at NWSL to see if he has the geared wheel sets. I bought some geared wheel sets for a Walther’s FM diesel. Dave is putting a list together of the different geared wheel sets he has for certain diesels.
Pictures below for the clueless. A Digitrax DZ125 is wired into the loco. Very good control.
Remove the caps from the motors and lift out the motors. Cut the clips to isolate the motor. Solder #30 wires to the motors and pickups. Be careful with the soldering iron, not a solder gun.
You will NOT find these motors at NWSL.
I bought my two motor off of eaby but saw a photo o
For the rivet counters, yes I know, this should be in the DCC Electronics forum but he wanted help.
Thank You, my friend, for your help, I won’t out-bid you; you have first right of refusal. Should you wish to pass, please keep me informed. I may wish to bid as well.
P.S - How are Ozzie & Harriet? (Hee, Hee? ) Just Kidding!
Jimmy
I just looked at my on-line profile and it says that I’m 2 yrs. old. Not true, I’m actually sixty yrs. old. Can’t figure how to change it. No, No, please don’t tell me, I will probably screw it up again! I’m good.
Jimmy
Goodnight, Mrs Calabash, where ever you are.
Jimmy
Sold out? That’s unfortunate. Maybe Bachmann will make them again.
I guess at the moment, finding an old 44 Tonner is your best bet. If it still runs well, chances are the gears will last a long time. I’m guessing this is for the Mack 15 Ton critters?
NWSL has a beautiful Stanton drive. Wheel base is 9’, 9’ 6" or 10’.
A fellow in a Yahoo Group is using them for a MDC boxcab shell rather than using the Spectrum 44 ton under the boxcan shell.
http://www.nwsl.com/motors-power-drives/stanton-drive
These people have more than 30 of them in stock with different road names. Here’s some of the links but there are several others. They are about 10 minutes from my house and have been around literally for 100 years. They quite often have hard to find stuff in many gauges.
http://www.nicholassmithtrains.com/store/product/42140/BAC-PRR-GE-44-TON-SWTCHR-%239330/
http://www.nicholassmithtrains.com/store/product/46629/BAC-PRR-GE-44-TON-SWTCHR-%239334/
http://www.nicholassmithtrains.com/store/product/33525/BAC-SPEC-B%26O-GE-44-TON/
http://www.nicholassmithtrains.com/store/product/18794/BAC-SPEC-B%26O-44-TON-%2319/
http://www.nicholassmithtrains.com/store/product/18799/BAC-SPEC-B%26O-44-TON-%2320/
http://www.nicholassmithtrains.com/store/product/18813/BAC-SPEC-BETH-STEEL-70-TON-%2344/
Darth Santa Fe
I e-mailed Bachmann to ask them if they would be making them again and they said no. I just scored an older 44 tonner on eBay and have bids on three more. Hope like heck I don’t win all three other bids - that will blow my budget for a long time to come!
Dave
Jimmy
There are still three 44 tonners up for bids on eBay. Two are new in boxes but date from the 1980’s. Prices are still reasonable but are getting close to $40. The third is at around $20 as I write this.
Dave
Off topic: If the NWSLs don’t work, he’s out or whatever, what about the Cable Car motor? http://estore.bachmanntrains.com/index.php?main_page=product_info&cPath=66_68_174&products_id=1205
As I noted earlier on my post, the link is to new in box from an LHS. No bidding necessary.
The last he told me is he is looking for a TWO MOTOR for a particular project. He wants to make a Critter. You cannot do that with a single motor 44 ton.
Flashwave
I have ordered one of the cable car motors that you refer to. I will let everybody know if it will work as a substitute for the 44 tonner power trucks. I am not holding my breath because the cable car power truck appears to be somewhat taller than the 44 tonner unit.
However, be warned that if the cable car truck does not fit into the Mack 15 ton critter I promise to build something else of a “crawley” nature around the thing! Rivet counters beware!![swg]
Dave
