456 Coal Ramp. Early version with the wire rail. ??????
Does anybody know how the wire rail on the early version ramp get secured in the upper, (tower) part of the ramp? And second, what is a close match to replace the wire? I know that the string on the later version is spring loaded and has an eyelet crimpt on the string line behind a small fiber washer, but on the early version, I can’t remember if it is the same. The repair manual shows for string line version only. Thanks in advance. Ric
I used aluminum welding wire for my coal ramp. I just bent the ends in the tower part to secure it. I guess you could use any small diameter stiff wire that’s the right length.
Pictures didn’t work. I’ll tray again.
Ric,
FWIW, the Lionel reissue of the #456 Coal Ramp (6-14005) uses wire rails. The tower ends are bent at a 90-degree angle and inserted into small holes in the tower.
The wire itself is silver-colored (stainless?), very stiff, and has a diameter just small enough to fit through the holes in the supports.
I don’t know if the original used a single strand of music (spring temper) wire or stranded but you can get either type from http://www.smallparts.com/ They also sell aluminum crimp connectors to terminate the stranded wire.
Pete
