Hi everybody, My name is Juan Carlos and I’m from Mexico [:)] I would like to have some suggestions about which track model build, I actually have a Bachmann limited edition train and I only can build a big oval [:|]
I built a 4’x8’ plywood table a few days ago and now I want to begin to make my layout [:D] but I don’t know how many tracks do I need neither wich model track should I build.
Can you suggest me a few ones? and how many tracks would I need to build it
I hope you can help me, thankyou and sorry for my bad english [:$]
I’m actually subscribed to model railroad magazine and I have seen that section from the webpage, the problem its that I can’t identify what kind of track should I buy to make the model I choose, there are a few ones that I liked it but how many tracks should I buy? what’s the radio of tracks?
You say you have a train set already. What type to track did it come with? Did it come with a circle of track or a loop? Knowing what type and brand of track you have will help folks recommend what more you need to expand your layoutl.
Would you like to have your model railroad look like it was mostly in the city or in the country? Do you want to let your trains run or do you mostly want to switch cars around in a yard? These questions will help folks come up with a design for a layout that will meet your desires.
There is quite a bit that you can do, even on a 4’x8’ layout.
Hi Richard!, I’m going to answer your questions hoping you can help me, actually my Bachmman Train set came with a 63"x54" oval, BUT I don’t want to build my layout with the E-Ztracks that came in my Bachmann Set, I want to buy a few Code 83 Atlas Tracks and that’s why I want to konw how many tracks to buy, and what kind of model have to build.
I would like to do a country model, fill my layout with trees, rivers, lakes, bridges, farm animales etcetera, it would be good that my train run and switch cars around yard , that’s not so important to me.
Once you have selected a track plan, you should be able to figure out which pieces to buy easily enough. If you really need to, download Atlas’s free Righttrack software (here: http://www.atlasrr.com/righttrack.htm). This will allow you to print a materials list, which will show you exactly what to buy.
That’s the point CTValleyRR, I don’t know how to identify what kind of track I am looking , I found a few interesting plans in the MR database, but I would like to have the ammount of pieces and the type of track to buy, I can’t find something like that
There are many decisions to be made before your questions can be answered comprehensively. What type of track, how complex a layout, how many sidings, how many turnouts, how much to spend, etc. I started by looking at all the layouts described on the Atlas web site. Then I bought several of the Atlas layout books. The books list exactly what track pieces are needed for each layout. If you do not like any of their choices you will have examples for how many track pieces are needed for a curve and how many for a siding. After I studied the books for a time I was able to plan my layout. The books can be found at…
There are many layout books from other sources on the web. A web search will find them for you. Language should not be a problem because there are many pictures.
I think you might have missed CTValleyRR’s suggestion about the Atlas track design freeware. It is fairly easy to use and as he said it will give you an accurate list of what pieces you will need to build your layout. What you will have to do is take the track plan that you have selected and re-draw it using the Atlas software. You don’t have to be precisely accurate as long as the plan you draw will fit in the space you have. The Atlas software will then tell you exactly what you need to build your track.
This is because most track plans in the MR database is not made with sectional track - most track plans are made with flextrack, which you bend to the radius you want/need and cut to length.
The track plan will tell you minimum radius and minimum size turnouts. Count turnouts, estimate track lengths by looking at the square grid on the drawing - it is usually either 12" grid or, for larger plans, 24" grid.
If you want to have precise instructions for building a layout, complete with instructions about exactly what pieces of track has been used where, then don’t look at track plans from MR - go buy a “starting in the hobby” type of book.
The February issue of Model Railroader is all about 4’ X 8’ track plans. If you could get this magazine it could be some help. www.ModelRoader.com They might send you a copy.
I used an “HO Layouts for every space” book (I think that was the name) by Altas RR. I took the HO-14 layout and built that. It has parts for both code 100 and code 83 Atlas track. Just another possibility.
