Dave-the-Train,
I don’t recall any B-C diesels in the US, but, as mentioned, B-A1A’s were made by both F-M (CPA24-5’s) and EMD (FL9’s & FL18’s…well, that’s what they should be called…they are after all a GP18 internally).
You also have some wacky electric wheel arrangements (like 1-B-B-1 or 1-C-1+1-C-1).
As for other odd diesels, you had Budd RDC’s with their 1A-A1 wheel arrangement, or wierder yet, the “Roger Williams” New Haven RDC train set with it’s AA-AA wheel arrangement. And then there’s the big Alco with it’s B-B-B-B arrangement, and the Baldwin Centipede (which was 2-D+D-2…I think).
Mark,
Actually, the FL9 was not built originally for 3rd rail service. It was originally a “water buffalo” design made for long distance passenger trains out west, as the problem out there was not the range of the loco’s fuel supply, but that they would run out of water for steam heat. According to an ex-EMD employee named Preston Cook (who gives public speeches about EMD, Alco, etc.), he discovered this fact while going through old EMD documents, and he even found and shows a technical drawing (an EMD catalog entry) showing what is described as an FL9, but with large internal water tanks both fore and aft of the prime mover and no 3rd rail gear.
It’s his conclusion that EMD created the FL9 design, but had no customers for it. The New Haven came knocking in 1955 for an Electric/Diesel-Electric design, and EMD dusted off their FL9 plans, pulled the water tanks, added 3rd rail gear, and viola! A NH EDER-5 (NH’s class code).
There’s some debate on whether the 5th axle was really needed for Park Avenue’s notoriously weak viaduct, as the 3rd rail gear isn’t nearly as heavy as the large quantity of water that wasn’t being carried. But it was probably just as easy to keep it than to design a while new frame. They certainly
