5x9 HO Layout Losing Power
I just now saw that picture that was posted…I have 8 extra EZ track power connecters (the ones that go from the power supply to the track/accessories). Can I just take a few of those and splice them together to connect to a power track on the other side of the layout? It almost seems like too simple of a fix.
Yes, you can. Just make sure the polarity is correct. If you get a short just turn the connector over.
Sometimes the simplest solutions are the best.
Myself, I’m soldering every other joint, and leaving every other joint “loose” (unsoldered), to allow for expansion and contraction. I’m using 36" lengths of flex track, so I end up with 16 GA feeders every 6 feet, and an expansion joint every 6 feet. Overkill? Depends on your perspective, but if I ever have train that doesn’t want to move, I have a reasonably good suspicion it WON’T be due to loose rail joiners.
Brad
Ok everyone, thanks for the tips. I’m going to go give “splicing” a shot. Keep your eyes on this thread for an update tomorrow!
