No, they are for solid telephone wire only. At least I have never seen stranded wire used on any of them.
No, they will take only 26 or smaller; standard telephone wire. They are usually used for 25 pair cable terminations.
Yes.
They are IDC terminals that usually require a special tool for pushing the wire into the contacts, and they are very difficult to work with without the special tool.
They come both ways 2x2 or 1x4. They make a slide on clip (bridge clip) to jump the rows but you cannot use wire on the terminal the clip covers.
The proper tool for 66 blocks costs more than $50. It has two blades, one to cut the wire and one not to cut to allow the wire to daisy chain to other terminals.
Since this is a 50 pair block, it is a split block. The 2 left columns of pins share continuity, but you’ll need to use the supplied bridge clip to carry signal across the block to the 2 right columns. How many blocks are you looking for?
I will tell you I have a proper punchdown tool and it has both sizes of blades - for 66 blocks and for 110 blocks and it did NOT cost me $50. It’s actually possible to do connections on a 66 block without a tool but you’ll have overhanging bits of wire you’ll need to cut off - the tool is the right way to do it. You can also double up wires on each pin, the phoen guys do it all the time. Not the best though becauseeither the top one is loose or makes poor contact compared to the bottom wire. For wiring signals and so forth though they are great. Track power - I wouldn’t recommend it. Telephone wire is a bit on the small side even for short track feeders. For a briefcase-size Z scale layout - perfect type of wire. For signals and low power things like Tortoise motors - again, great choice.
I’ve used needlenose pliers many times to punch down wires on 66 blocks, when I didn’t have a punchdown tool handy. There is a technique to it and I wouldn’t recommend it but it is doable.
