7.2 volt
i had a idea for rc locos and wanted to know if 2 7.2volt batteries would b enuff 2 power a loco??
In series two 7.2 Volt battery packs will give you 14.4 Volt -which is normally sufficient. Do not put NiMH or NiCd battery packs in parallel as this can cause premature discharge.
On a point of information… Please try to use International Standard English as this is an international forum and local sang and abbreviations can cause vast confusion and leave some artichokes loaf of bread in a right 2+8(!)
regards
ralph
not a problem. just i have a harnes set up from a old nitro truck that i can use for locomotive (gp 30)
Hi [#welcome] To the forum it helps if you give other members an idea where you are in the world, then any close by may be able to help on site if thats what you want or a meet to sort a problem. Its no compulsery but it helps[:)]
[#ditto]
7.2 volts will be sufficient for small critters and locos, things like an Eggliner, maybe Bachmann’s railtruck, and some yard switchers where speed isn’t a priority. If you have room for 8.4 or 9.6 volt packs, that will give you just a little extra headroom.
Later,
K
Live powered a small critter with 1.5 v
Funny thing Ralph is this international forum from the U.S. (United States) is both English and Spanish or as I call it mixed English and mixed Spanish. [:D]
I would like to see the Internatioal Standard English guild?! [:D]
ERRRMMM…
Toad -what makes you think that ENGLISH is my native language?
Drar enegis anthar voor mid ed geenderlish nie en
As others have there standard, just jacking with yeah lol [:D]
Toad (poken Ralphs side abit [swg])
