Hi Joe,
An EXCELLENT book for you to look for is Kalmbach’s “The Modeler’s Guide to Logging Railroads”
Printed in 2008, 77 pages, Many Great photos, and a Lot of information, MSRP $18.95 item# 12423. Written by Matt Coleman.
If running disconnects, they were almost NEVER pushed, and with skeleton cars, pushing was limited as much as practical, especially after air brakes and knuckle couplers were adopted. According to this book, “The Larger California Narrow Gauge logging lines were all air-brake users relatively early” pg 41.
On lines with steep grades, which were common to logging lines, the locomotives would be oriented FACING uphill, to keep the firebox crownsheet covered with water.
Steam Locomotives in mechanicaly, run equally well forward or reverse. Many logging Rod locomotives had trailing wheels under the cab/firebox more for better tracking in reverse, than for weight carry reasons, as many logging lines had no provision for turning at one or either end of the line, it was common for locomotives to run as many miles in reverse, as they did forwards.
On the West Coast in particular, later in the logging era, it was common to have a “Main Line” built to better standards on lines with longer runs, that would use rod locomotives for the long haul, and use temporary “Branchlines” to reach cutting areas. These branchlines were typically laid quickly, with minimal roadbed preperation, and sharp curves and steep grades. these braches were typically used for one or two cutting seasons, and when the viable timber was removed, pulled up and relaid in new areas to reach new timber. Geared locomotives were commonly used on these branches. While Heislers were known to be “A Bit Faster” than the Shays, and some Climax locomotives had a two speed gearbox, none of the geared locomotives were what would be considered Fast machines by any stretch of the imagination.
Doug
