First let me explain what my goal is.
1.) I’m trying to get my old layout running from circa 1978. It’s a mix of Tyco and Atlas track to make an oval with an inside passing line.
2.) I have three helpers aged 5(in a few weeks) 3, and 2. So I want something durable but not a massive amount of time or cash. A starter set for the boys if you will not my dream model RR.
I’m posting here because this forum seems to be a little more open to these questions:
I’ll be replacing the old brass track with new silver-nickel track but want to pratice first. For some reason my brother pulled up the track and I have it loosely put back in place. Cleaned w/ a bright boy and the track works ok but have some dead spots.
1.) When you solder the track together is it required to remove the ties or if you’re careful can you skip this?
2.) Any track components that I should avoid soldering i.e. turnouts?
3.) My 25 year cork has seem better days any suggestions on a roadbed? Never ballasted it since I couldn’t decide how I wanted it to look.
4.) Rerailers are they really necessary if you lay the track right. I have 18" radius curves to fit to a 4’X8’ table.
5.) Wahl Clipper oil where is it availible? I need to clean my locomotive wheels or other methods?
6.) is there anywhere that I can find exploded views off how to disassemble locomotives for cleaning and lubrication? I have some 70’s series Tycos, Baumanns, Athrean and AHM.
7.) With the AHM the wheels in the back truck were loose in the box. Is there anywhere I can find a set off assembly instructions? I need to figure out if the axle wiper goes above or below the axles.
8.) I’ve tested out the power unit and it’s ok… Anything else I need to check out?
9.) Besides changing the grease in the gear box and lubricating the motor are there any other areas I need to check out?
10.) Of course getting bac
