Yesterday I bought a broken box car at a model shop. It was close to Kadee’s PS-1 and cost only $3.00 including tax. Strangely enough, despite such massive damage, the roof walk and ladders were safe.
Disassembled and surprised. The floorboard made by die casting was cracked. It was so brittle that it cracked just by touching it with my finger. This is “zink pest.” Perhaps the plastic roof’s deformation has solidified due to creep over time. Do you know the manufacturer or the release year of this model? Has anyone experienced any repairs?
By the way, what is the English meaning of the word “pest”, insect or disease?
When Marklin moved some of their operations to China it seems that there was a rather extensive run of “zink pest” affected models in 2005-2006. It also affected some very expensive locomotives.
Over the years I have bought quite a few of the Trix U.S. based cars and some are perfect, yet others suffer the fate as shown in your photo. In a few cases the zinc floor had expanded so much that it cracked the body at the door sills from the stress.
In some cases the underframe can be easily swapped with one from a MTH brand box car. Others may work just as well but I happened to have several MTH cars and their body shell isn’t very well detailed but their underframe was. I recall that I filed off the four mounting “nubs” and used a very small amount of Walthers Goo to secure the body to the floor but still be able to break the bond if necessary.
While I’ve used the Central Valley underframe for their stock cars…
…and under these heavily modified Blue Box Athearn cars, too…
…they place the trucks very close to the ends of these cars. That’s not to suggest that it’s unprototypical, but it reflects a fairly old practice, mostly from the '20s and earlier.
The Pennsy used a similar truck position under their X-29 boxcars (and possibly other car types, too) so it’s not uncommon, but it is relatively outdated for boxcars.
“Zinc pest” is from the disease sense (as in the English ‘pestilence’): the problem appears as if due to a spreading malady.
What causes it is changes in temperature, not exposure to moisture or physical damage; it is not (at least not initially) a form of ‘corrosion’, but a phase change in the alloy of which the part is made, similar to the change in tin ‘allotropes’ between white and gray.
As such, there is no ‘cure’ other than to keep the part at a reasonably stable temperature; as I recall, it’s allowing the part to become cold (as in an unheated attic) that starts the process going – similar in a way to why enamel watch dials can crack over the years.
There is no real ‘cure’ other than by removing the phase-changed areas, putting the straightened parts in a jig of some kind, and casting material around them to bring back the part’s dimensions. Then keeping the repaired part at as constant a temperature as you can manage…
A large problem with early zinc die casting materials was zinc pest, owing to impurities in the alloys.[3] Zamak avoided this by the use of 99.99% pure zinc metal, produced by New Jersey Zinc’s use of a refluxer as part of the
That’s sad to see. When those Trix cars were new they were noted to have some modest flaws in terms of prototype replication but were nice models and by no means inexpensive.
THe phrase “Zinc pest” is fairly new. I knew it as “zinc rot” and it (the phenomenon, not the term) was common even going back to some Lionel trains of the 1930s. My initial trainset in HO was Penn Line and its trucks suffered from zinc rot. So did many parts of the Varney F3 all metal diesel loco model.
This little brass Mogul, belonging to a friend, had a bad case of zinc pest in her driver centres (I first heard that term in the '50s, from my dad, and have always referred to it as such. I suspect that for him, the term went back to at least the '30s).
It was so bad that the screws holding the siderods in place kept falling out, rendering it inoperable.
That’s the restored version in the photo, with all-new drivers from Greenway, a new can motor and a NWSL gearbox. She runs better than she ever has.
I’ve also had early cast-metal truck sideframes and/or bolsters pretty-much turn to dust, and have seen cast zinc boilers with enough zinc pest to make them unuseable.
I think that the Kadee trucks are something different - at least some of them. Their sideframes are listed as being either metal or HGC, what Kadee calls a “High Gravity Compound, weighs nearly the same as Metal Trucks but with more detai…”
I have a few very old Kadee couplers, some still in their kraft-paper envelopes, and they have definitely picked up a type of zinc corrosion. It may not affect the strength of the coupler but it does result in loss of finish and a pitting of the surface.
Admittedly, these were stored in damp basement conditions and these couplers are at least twenty years old.
If they arent too bad I brush them with a soft brass brush and apply a graphite solution to them and they seem OK. A few have decayed to the point of no return.
Speedwitch Media makes a resin replacement underframe for the Trix Union Pacific boxcars. While he made it specifically to match the welded underframe details of the UP’s version of that car, other Trix 40-foot boxcars use the same body and frame, so it would fit those, too.
I’ve read that the underframe from an Accurail steel 40-foot boxcar kit can be made to fit with only some light sanding.
So, THAT’S what it’s called. I was given some old Athearn passenger cars and the metal trucks had this chalky texture to it. I never bothered trying to fix those trucks. Especially ones that had split wheels (the wheels would be cracked from the axle holes out to the tread. I’ve never recalled seeing a thread on replacing wheelsets on those trucks either. The bolsters used some kind of swedging process to attach them to the sideframes. I still have some of those trucks, if anyone knows how to disassemble, and reassemble, them.
That’s a different thing called weissrot. It is a zinc corrosion too, but is mainly a surface corrosion rather than zinc pest being a problem in the crystalline structure of the metal.
