I bought a 726 and I need some help. I took the shell off of the engine to clean it, and when I put it back on the engine shorts out and doesn’t run. Can you please help.
Wire pinched between boiler and frame?
Run it at night with all the lights in the room off and you might see where it is sparking. You might have to run it with the shell off.
Good Luck…
Earl
It’s fixed, it was a pinched wire. Thanks everyone.
