A question for Buckeye??
Buckeye, I recall at one time you posted a tread on some work you did on some switches where you added strips of plastic to them to make them work be
Kevin I will tell you this about that. It was MTH switches. Now what you need to do may be helped by what he used. I don’t know but thought I would let you know it was MTH switches Him and chief both had problems
Thanks RT, I knew that. just thought I may be able to do the same thing to fix the wear on mine.
