Does anyone know if there is a factory reset for the System One command station and/or throttles?
Thank in advance.
Thank in advance.
I believe North Coast Engineering took over the Wangrow System One product line, so you might try contacting them with your question.
Thanks cacole, I also asked on the NCE Yahoo Group hope to have a reply. If not I will try NCE as you suggested.
I was looking around the web for information on a Wangrow accessory decoder and happened upon a site that has what appears to be the latest or possibly last version of the Wangrom system manual. It is about 270 pages. I didn’t look through the whole thing, but I suspect that it has the information you are searching for. There is a section called “set command station” on page 4-24. Maybe that will help you out.
The site is:
Good luck.
Thanks for the link Maxman, I was able to reset the system to factory default and now everything is Ok.
Jack W.
