I need a power supply made to supply power to a pyle national gyralite. I need to go from 120ac household current to 74vdc with about a 3-5 amp capacity. I will know for sure on the amps once the light arrives, its a single beam unit. depending on how its constructed, I might try to modify it to 12v operation with a different motor and bulb. But I also have a Prime digital beacon that could be run by this powersupply. Thanks Mike T
You might try this.
http://www.sola-hevi-duty.com/products/powersupplies/Index.htm
Most ran with 74 v DC WITH 30 -32v for a 200 watt bulb.You might have to find a 74 v. 4 a. transformerwith a 10 a. of brige rectifyer, and build your own.
A 115v 200 watt conventional bulb might work for the latter.
Mike;
I would get a Variac, a high current bridge rectifier, an on-off switch, and bolted shut box to put the variac and rectifier into once you have set it for the correct voltage.
http://www.allelectronics.com/cgi-bin/category.cgi?category=805&type=store
http://www.allelectronics.com/cgi-bin/category.cgi?category=110&item=FWB-156W&type=store
Another place you might want to check is C&H Sales in Pasadena, CA. They sometimes come up with some strange military surplus electronics items, and they just might have a power supply with the outputs you need.
Type C&H Sales into Google and they should be the top entry.
