I am sending along a picture schematic of what I sent Tony of Tony’s Trains after buying his PSX-AR.
As you can see, he has sketched in the placement of the reverse block. The red and black are my buss writes and correspond to the track feeds, so as can be seen, I have one spot at the lower left turnout where track polarity will change. If I am running a loco counter-clockwise, it will be OK until it hits that turnout, when the right and left wheels will experience a change in polarity.
Tony claims that with his diagram, that is not problem??? I am not real good at figuring these things out but it seems to me that I have a short waiting to happen? [*-)]
If so, how would one wires the circuit? I just cannot get my head on this. []
Why would you run your bus wires in a reverse loop configuration? The bus will have to be broken into a main line portion and a reversing unit portion.
Simply gap both legs of that turnout. The main bus feeds the point side and output from the reversing unit feeds the frog sides past the gaps.
Texas Zephyr - that is what I did (those gaps) but Tony claims they are un-necessary. I do not plan to have the buss wires in the reverse portions but there are track feeds outside of portion that are wired to the busses as shown.
Do I need to move the reverse portion back to the level of the turnouts and then have no buss feeds on the “loop” sides of the turnouts? [D)]
If your bus wires follow your track, here is the required setup.
Gap the rails where the circles are placed on the following diagram.
When a train enters the reverse section by crossing the gaps, the PSX-AR flips the polarity to prevent a short.
The following diagram shows the resulting flipped polarities.
The reversing section should be longer than the longest train so as not to confuse the PSX-AR.
If a train continues on a straight route and does not follow a divergent route across the crossover, the polarities remain in phase, and the PSX-AR is not required to reverse polarities since no short will occur.
In other words, the only point of reverse polarity is where the divergent tracks of the two turnouts, forming the crossover, meet.
If those three tracks leading off the crossover are stub ended and not connected elsewhere on the layout, you are fine as long as they are above the gaps that I drew on the crossover.
If they are connected elsewhere on the layout, or if they might be in the future, you could add gaps to the rails at the end of the divergent track on each turnout. In other words, you could could gap six additional rails.
Rich - sorry to be so long in replying to your kind comments but I am now in Florida taking care of my Mom for a week.
I have been ruminating on this plan and now realize that you had changed the buss/track polarity at that lower left turnout, and so I understand how that would work.
But i am afraid that i simplified things WAYYYYY too much and now I have re-drawn my true track plan (except for the reverse crossover on the other loop to the left). The trackage is more complex than i lead you to believe and now I see more major problems.
First I am wondering if, given all the turnouts and yard on the top, if it would be possible to put the reversing circuit to the lower left turnout area? I am also wondering what happens if a second loco enters the loop at the same time?
The way I see it, feeds 1,5,7,6,8, &15 are on the main buss, while #2,3,4,14 are on the out side of the PSX-AR.
Then I am not sure about feeds #2,10,9,11,12, & 13. I think at least those yard tracks should be gapped, otherwise they will draw main buss power if that is how they are wired to the main buss as I have done them??
As you can tell, I am overmatched with this layout but know there must be a way to right it. All I know is that Tony’s solution will cause me to blow out my Zephyr again.!! Don’t need that. [+o(]
Rich - that is the track plan, only with the track polarity marked. Also, my turnouts are all insulated or gapped(either Atlas or hand-made Fast-Tracks #5).
I hope i have clarified enough, sorry to be so slow to the uptake. If you want me to trace the tracks again, please let me know.
One concern is that set of bus wires that end abruptly and are marked with a #10 in your bus wire diagram. Is that meant to represent a stub end track, such as a spur?
The other concern is your earlier statement that you have now “re-drawn my true track plan (except for the reverse crossover on the other loop to the left)”. I am not sure what you mean by the term “reverse crossover” and what you mean by “the other loop to the left”. Can you draw that part of your track configuration ? That could be crucial to proper wiring.
Rich - thanks for hanging in with me. I have internet connection again, so I re-drew what my track looks like. I took off all track feeds and am just showing the track polarity as it is now wired, including gaps that I have made. Yes, The #10 is a spur for a switching lead. I have also given some crude dimensions to let you know how long the tracks will be. The loops are 4’ each. So there it is as laid for now.
I would gap the following 4 places and make the blue section the reversing section.
Depending on how long the bottom crossover is, you may need to move the gap that is below the crossover further into the loop. It may even make sense to move it all the way to just beyond the other turnout on the crossover.
Thank you Allen - as usual, I forgot one other detail,I have 2 reversers to use so I will make 2 such separate loops. Now I just need to know how to wire the drops from the busses to keep the polarity so I don’t blow up another Zephyr! [oops]
You can have one set of bus wires with two auto-reversers. The key is to correctly gap the rails to isolate each reversing section.
The only feeder wires that should be connected to the input side of each auto-reverser are feeder wires from the bus wires outside of any reversing section.
The only feeder wires that should be connected to the output side of each auto-reverser are feeder wires to the rails inside the reversing section controlled by that auto-reverser.
No feeder wires within any reversing section should connected to the bus wires.
Rich - thanks for all the support. I do understand what you are saying and it makes sense. I had an epiphany [:^)] last night as I was trying to get to sleep [|)]
I can do what Tony originally said if i keep the buss feeds to the non-reversed tracks in the same polarity throughout the layout. Instead of having the polarity follow the curves, I am going to treat it like I started before, and thus leave all red to the inner track and black to the outer, then i only have to figure where to put my reversing sections within the curves. WOW, how one it has taken for me to figure that! [banghead]
One final question - what happens if a second train enters the reversing section while a first train is still in it? Maybe that is why one should keep the reverse section as small as a train length (or is it a locomotive length??)
