I have a question, I building a returning loop at one end of my layout,it’s coming out as the main line from a yard with a crossover but it WILL NOT be a ballon track, it will just go back as double main line into the yard, the double main line won’t meet until the other side of the yard, will this still be considerd a reversal loop??? thanks… Tranisrme1
Trains: Don’t quite visualize the layout you describe, but this will answer your question. Get two different colored pencils and trace the North rail with one and the South rail with the other. Doesn’t matter where you start. If one color meets the other at any point on the same rail, IT"S A REVERSING LOOP and must be wired as a separate block (isolate both rails at both ends of the block, which should be at least one train length long to prevent problems with shorting across the “joints”.
This sounds like you are building a reversing loop. However, a problem only occurs when you connect back to the track that started the loop (or a track connected to it). Somewhere before that happens you need an electrically isolated section of track that should be as long as your longest train. This track can be partially or wholly in the loop itself or along your main line as long as it occurs before the first connection (crossover, etc.) back to the original track. This isolated section is your reversing section regardless of whether it’s in the loop or not.
If you haven’t already, pick up a wiring book - Kalmbach has a basic one for DC and one for DCC as well as other electrical books.
Trainsme1–sounds like a reversing loop where after the yard going back onto the mainline in reverse direction you will need a polarity change at the mainline turnout. DPDT switches will work or PSX-AR if DCC.
Take a cheap boxcar and paint a large + sign on one side, and large - sign on the other. Push it around your layout. If the plus side doesn’t suddenly encounter a piece of track that should be the minus side, you have no reverse loop.
