I’m in the process of designing a New N scale layout using AutoCad. I have a couple of Peco curved right hand switches I would to incorporate into the New Layout. Does anyone know or can provide me with the actual radius of these turnouts?
Thank You
Thank You
All of the information is right here:
http://teladesign.com/british-n-scale/peco-turnouts.html
Code 80
Streamline Curved Double Radius Turnouts, code 80.
Nominal Outside Radius: 914 mm; 36"
Nominal Inside Radius: 457 mm; 18"
Frog Angle: 10 degrees
Length: 157 mm; 6 3/16"
Insulfrog RH SL-386
Insulfrog LH SL-387
Electrofrog RH SL-E386
Electrofrog LH SL-E387
Code 55
Universal Fine Curved Double Radius Turnouts, visible code 55.
Length: 159.5 mm; 6 9/32"
Electrofrog RH SL-E386F
Electrofrog LH SL-E387F
Hope this helps,
Jim Bernier
