I have an Atlas Master #9111 GP-38. It has the older DC/DCC decoder - runs well on DCC but I would like to have sound to match up with my other locomotives.
Should I replace the entire decoder or just try to add sound (if that’s even possible)? Either way, what are your recommendations for decoders or sound for this locomotive? I’ve never really delved into the DCC guts of a locomotive, but I’m willing to give it a try with this one!
One decoder that does sound and motor control is almost ALWAYS better than trying to use two different decoders.
The hardest part of installing sound is usually finding place for the speaker. Your best bet is to check Google and see if you can find examples of installation in your loco.
My preferred sound decoders these days are the Loksound Select series. Excellent sounds and great motor drive for smooth operation.
I too would recommend the Loksound decoder. The simplest installation would be to use a Loksound Select Direct decoder (direct replacement for the Atlas board) and have it loaded with file number 73826 which is correct for the GP38.
If you’re not keen on cutting down the weights to install a speaker, Loksound also has a new cell phone speaker set which includes the speaker and parts to create a custom enclosure. You could probably install it easily in the cab area without having to do any modifications. Part number 50321 …
Don’t be fooled by the tiny size of that speaker. It honestly sounds as good as a 16mm X 35mm speaker which would require almost removing the entire rear weight to fit it in.
You can see from the GP40 that they addressed the speaker room by simply removing the rear weight. Easy, but maybe not so desireable from a traction standpoint.
Based on what I see, one question is how comfortable you are with soldering, or learning that. Given what I see, I’d second the recommendation of removing the old light board, decoder and lights. Then add a LokSound Select 6Aux decoder, on a piece of styene glued above the motor, towards the front. That Select version is smaller (shorter) than the board replacement Direct type, only about as big as the smaller TCS board in the
Thanks for the tips, guys. One reason I chose to do this loco is that it is my least-favorite, so on the off-chance I destroy it, I won’t cry too much. i guess I’ll dive on in!
