Adding a High Hood to an old Athearn SD45
Hello, I wanted to know if anybody has added a high hood to an old Athearn blue box SD45. Does Cannon & Co. make a hood that will work with these. I know the hood is approximately 1 foot too wide on the model versus the prototype, but I have several of these and would like to convert them for N&W. Any help will be greatly appreciated!
Kbaker329
Yup, the problem is the width of the hood. It will look quite funny. You are better off finding either a RPP SD45 shell or buying a Proto SD45 and starting there. Then the Canon and Company high hood will fit just fine.
David B
You can add a Cannon HH to the old BB SD45 and it will look ok…
Better then using a P2K use the new Athearn SD45 with the High Hood.
http://www.athearn.com/Products/Default.aspx?ProdID=ATH95410
Street price should be between $69.00-72.00.
I almost bought a custom Athearn “fat hood” Guilford SD45 with a Cannon scale-width nose (the seller misidentified the loco as a Bachmann Spectrum when he told me about it. The Spectrum has a scale-width hood). It looked really weird with the two different width hoods. If you really like the wide hood SD45s, the only thing I can think of is getting some of the old Athearn wide-hood GP35 shells and making high noses out of the long hoods. That being said, might I suggest the new high-hood Athearn RTR SD45? I have one, and I highly recommend it! [:D]
I bought a custom High Hood GP35 off of a lot on eBay.
I always run the high hoods opposite of the N&W and NS…I run mine HH first. With the scale nose I never notice the hooribly off scale body.
However, this doesn’t work in your situation.
You are best off finding a RPP SD45 shell (they can be had cheap on the net). I really don’t know what to tell you to do with that Athearn shell. You CAN put it on, if you want.
Phil
Don’t even bother with the old BB SD45. Wait for the new Athearn RTR one’s to come out. The frist release will have a NW high hood. Check our Athearn’s website.
I did one with a SD45 from P2K and used a Cannon and Co. for it. I was easy. Here is my MRL #680 that I created.
The Cannon parts are for scale width hoods but it would be possible to adapt the kit to go on an Athearn BB SD45. Some sheet styrene to make a wider top for the long hood and fill in the gaps on the sides where the hood end joins the sides of the hood. A little work but possible.
