all my BB locos are now going to get decoders, they are wired as 5-wire style (DC)
I have a light board and an 8-pin decoder, what wires do I need to move and or fix?
my original wiring is done this way + wires are soldered to the truck engineer’s side frame and the - wires to the other side frame, LED lighting is directional. athearn DCC-friendly motors, no sound. Well, that is about all for now.
Hi John, it has been some time since I have hardwired a Athearn BB loco. First things first make sure the loco is a solid and decent running loco with DC, DCC will not improve any poor running loco.
The motor needs to be isolated from the frame, remove it and place tape over the contact strip in the bottom of the frame, swap the copper motor clips so the clip with the two prongs is on top of the motor and not eating into the tape. While you have those motor contact strips off solder you orange and grey decoder wires directly to them. Go easy removing the contacts as springs and brushes are under them and they will fly away forever.
Solder red and black pick up wires to each side of the truck frame with additional wires between each truck for 8 wheel pick up.
Remove the bonfire in the cab bulb and wire in an LED behind the headlights, get creative with using a straw or heat shrink to hold LED in place.
I use to try and place the decoder under the DB blister as there is limited room inside these locos.
Good luck.
There is a decoder available that hooks into this loco without soldering but in my opinion it’s not worth the additional cost.
Basementdweller does a nice job of explaining the basics of the process [Y]
The decoder harness that was simple no solder install on Athearns in no longer availiable. I didn’t like them any way, they didn’t provide good solid contacts.
There are a zillion YouTubes on doing this as well.
A big percentage of my locos are refurbished and dcc hardwired Athearns.
I’ve also put decoders into old BB engines for my layout. I used the traditional Kadees. This can present a problem depending on how the couplers are mounted. I make sure they are mounted in plastic Kadee draft gear boxes, which insulate the coupler shafts from the engine frame so the couplers never receive rail power. In some installations that use the frame as part of the circuit, if the couplers are hot you have to watch which way the locomotives are pointed in a consist to prevent shorts.
DO NOT USE THE FRAME AS AN ELECTRICAL CONDUIT (PATH)!!!
If you do not isolate the trucks and motor from the frame you will fry the decoder.
To completely isolate the trucks and motor from the frame you will need to remove them to perform this surgery.
To swap the top and bottom motor clips you will need to cut the long top clip at the point where it clips onto the motor and use this as the bottom clip.
When I am converting an Athearn BB to DCC I go so far as to paint the well in the frame, under the motor, with “Liquid Electrical Tape” available online or at your local or big box hardware store.
If you are a “Suspenders & Belt” kind of person you can also add Kapton® tape to the bottom motor clip.
Athearn BB truck towers have an upside-down “L” bracket that contacts to the long upper motor clip.
I cut off the inverted “L” bracket flush with the sides of the trucks.
On the opposite side of the trucks, there is a bracket that contacts the frame.
This contact needs to be cut off at the same point you cut the other bracket.
Now the trucks and motor are completely electrically isolated from the frame.
[quote user=“basementdweller”] While you have those motor contact strips off solder you th
Note that if it came with a lightboard attached, some early ones with the lightboard did not have the motor isolated from the frame, so you still have to do that. If it doesn’t have a lightboard, you can add it, or get an 8 to 9 pin harness and just do it that way. If you use LEDs, you’ll need to add a resistor in that case.
Ok, everybody, the BB engines are good old BB engines. The light board I bought has an 8-pin receptacle for the decode and is plugged in now. The LEDs have resistors, the frames are isolated from rail power, and all of the after for the mentioned wiring is done but the engine motor power wiring.M1 M2 on the board.
all this is so hard to convey but with all your guy’s help I can finally get at least one working properly
If you’re using a lightboard, you probably don’t need to add resistors; that’s kinda the original reason for lightboards pre-DCC. Using a regular 9-pin harness is probably the easiest way to convert a BB engine, and there’s a lot of info in books on DCC and online showing step by step how to do it.
For engine headlights I like to use Evans Designs LEDs that come pre-wired with a resistors so you can use it with any power source up to I think 15 volts AC or DC without needing to add anything.
once you cut the engineer side bracket side off how do you hook up the truck to the frame? ( it does have the locator pinhole?) I know stupid question. But if you don’t cut the bracket off can you put a thin shim there to do the isolation factor?
Yes, a shim of thin styrene can be used to insulate the bracket (bolster).
However, if the shim wears through and the “live” bolster conducts with the frame bad things happen quickly!
Another option would be to make the bolster out of thicker styrene and use "Thick " or “Gel” type CA (Super Glue to carefully adhere it to the trucks, being careful to not get any CA on the gears.
What I’ve done when making this conversion is carefully cut the top of the bracket off and file it even with the plastic on the truck creating a gap between the two metal pieces.
Then I use two-part epoxy to reattach the bolster.
An advantage to using the thicker 2-part epoxy is that you can control where it goes and once dry, it provides some insulation between the two parts.
Then you solder the wheel pickup wires to the metal sides of the truck.
As Albert Einstein was credited with the quote…
“Once you open a ‘can of worms’ the only way to get all the worms back in is to use a bigger can.”
Many of these conversions or “upgrades” require a “bigger can”.
what I did was cut off the bracket and file the little metal piece to fit I used CA, but it came off, and now I have wasted trucks . I’m going to use shims from my computer building stuff very thin but made out of hard fiber. The next set will be as you said epoxy oh ya , already bought some two-part thick.
Can you elaborate on how using the frame as a negative electrial path will fry a decoder? Seems like the frame would just be a “wire” from the truck pad and one could simply run wire from the frame to the decoder. In theory anyway.
The Proto 2000 BL2 locomotive I’m dealing with does not have a plastic tank cover.
The metal frame is just painted black.
If the frame shorts out on the track power by derailing it can fry the decoder and possibly damage the DCC components if they are not protected by a circuit breaker.
This can also happen if the couplers are metal and not isolated from the frame when using the frame as an electrical path.
When the trip pin shorts against the rail it can fry the decoder.
The best practice is to completely isolate the motor from the frame and use wires from the wheel pickups to the motor.
