There have probably been posts on this before and I did do a search but when I hit the the 175th old post and didn’t find an answer I decided to raise the question again.
I am adding a 12 x 5 extension on my layout and need to splice into the existing track bus for the addition. What is the recommended way to do this understanding that the ends of the existing bus are taped to a riser.
Thanks
Right off hand, you could just solder the two ends together. Maybe use suitcase clamps. I use buss bars for my entire layout. Main feed goes through and track sections are routed to them. I try to keep the track feeders less than 18in or so. Haven’t had a problem in 4 yrs.
Thanks Phil - that was my plan but just wanted to be sure there wasn’t some particular way because it is DCC.
Make a Western Union splice, solder the joint and either use plastic tape or shrink tubing to insulate them. Or you could use a Barrier strip and crimp eyelets on the wires or wrap the wire around the posts. Anyway you are comfortable with.
I second the wire nuts, if there good enough for the wiring in your house they will work just fine for your model railroad. Which doesn’t run any where hear the amperage your house does. I’ve seen them used many times.
By using a barrier strip you can easily disconnect the new section if power issues come up and you can isolate that part of the layout. Just a thought.
I agree. Putting in barrier strips takes a little more time but they can really save you a lot of effort when you are trying to diagnose a problem. They have been a real help for me.
Joe
