Hi,
Does anyone have any suggestions on how to add weight to husky stack cars.
I was going to add weight to the containers. I believe the car should weigh 5.75 oz.
Chris
Hi,
Chris
That’s exactly how I did it, but limit your added weight to the lower container to keep the center of gravity as low as possible. The space under the end platforms is very limited, so not much can be added there.
My suggestion too. Keep the weight in the lower container.
[#ditto]
Keep the weight as low as possible.
I weight all containers and trailers usually 1/2 to 3/4 oz each. I load them top and bottom and don’t have any trouble. If they rock a bit when running, well that’s just proto-type operation.
Tilden
