Hello Railfans!
While reading another thread (bad electrical pickup on a Bachmann tender) I came across a procedure Ive known about, but dont do. Adding weight to a steam loco tender to enhance its electrical contact to the rails.
When i have this electrical problem I come at it from an electrical path problem view (fix the path) and that works. Im quite sure adding weight to the tender would work too, i just dont do that.
My questions are following, aside from it gaining better electrical performance, how does this added weight affect the pulling power of the model?
I sometimes use extraordinarily weighted cars (test cars not layout cars) to simulate the weight of a long train when breaking in or servicing locos. My loco fleet is unaltered, loco or tender, concerning added weight. I would add weight over the drivers to increase TE when a layout of size becomes available.
However, Im curious. When i use the loaded cars, i see how the model works under the load. Adding weight to your tenders would seem to decrease your pulling ability because the model now weighs more as a stand alone unit (no train). Thats more work on the motor than in its stock oem form and theres no train behind it yet.
Have any of you noticed this? Has this posed problems? Also consider, some of you may use correctly weighted cars too. Now thats more weight in tender, plus weighted cars. That HAS to drop the ‘tonnage ratings’ on your locos. Does it?
I know wre talking small weight amounts here, but it all does add up, and you can measure it on a volt and amp meters.
(I also forsee heat problems too… anyone?)
Thanks for the info!
PMR
