Adobe Flash Player Message
Hello All
Starting tonight I’ve been getting an internet message that a program wants to open web content with adobe flash player. Every time a window in this site changes I get the message. I don’t know if there’s a rogue advertiser causing it but will the host please fix it.?
Maybe it’s the advertisements. Do you have firefox? If so, I recommend you download the plug-in called Adblockplus. And you can just block all the advertising stuff. That’s what I do, it works great.
I use Internet Explorer. I have the pop-up blocker turned on, and I have never experienced the message you described.
I have not seen this on this site. Run Malwarebytes, you may have something that is doing this. There have been several updates to Flash player over thepast few weeks, if you didn’t install these you may hvae been hit by whatever the update was trying to block.
I run Firefox web browser with Add On’s, adblock plus 1.0.2, Flash Block 1.5.1 and download helper 4.8.1.
Never see what the OP sees.
Does it still do it today?
I don’t have that. Then again, I have always run IE and haven’t had any of the problems others say they have with it either so… maybe I’m not a good example.
