On a permissive red signal, an engineer is allowed to proceed provided he (or she) is moving at a speed that would permit him to bring his train to a complete stop before striking any obstruction. Certainly obstructions would include any train ahead, including any passengers boarding or disembarking at a station.
I would like to know how “obstruction” (my word) is formally defined, and if it would include something like a large tree across the track or a washout around a blind curve, something a train might well hit had the signal been green.
I never thought the railroads would deliberately test an engine crew in such a manner. Don’t all locomotives carry black boxes that can be examined after the fact to show what ensued from start to finish on any given run?
Seems such efficiency testers could be put to better uses, like determining why so many derailments occur each week. Those are track and rolling stock problems, not engine crew problems.
dont have the pass/fail numbers…but if a crew fails…they are taken out of service… hitting a simulated obstruction device as they are called…is treated just as if you went by a red signal…
My understanding of permissive as used on the PRR was if a train had to stop on a grade it was permitted to proceed at a very slow speed past the stop indication prepared to stop. Today I would expect the bulk of permissives to be near yards where trains can stack up waiting for a track. Hitting one should be fairly difficult since crews can talk by radio and tell each other approximately where they are.
Quote: " . . .dont have the pass/fail numbers…but if a crew fails…they are taken out of service… hitting a simulated obstruction device as they are called…is treated just as if you went by a red signal…"
That does sound like a very good test to see if an engineer knows how to deal with a permissive red correctly. Safety first, last and always, but it would seem to me that the engineer could also get (fired, reprimanded, etc.) if he stood stock still at a discernible, permissible red.
On the Pennsy main line, the old track-spanning signal towers are coming down, undoubtedly to be replaced with something simple but reliable. I don’t know if CTC is a prerequisite the carrier had to have or has to get in order to go to the very simple CPL-type of signal, but it would make sense.
It would also make sense to that me under the old system of multiple signals conveying essentially the same information but under different modes or arrays of communication–that it just might give extra context in an ambiguous situation like shall-we-go-slow or shall-we-stay-put. Perhaps the veteran hoggers could chip in on this: were redundant signals (all giving the same basic command) of more help in unusual situations? Lacking radio-tel communications with a road-wide Central Dispatcher, possibly lacking any radio, possibly, not on CTC, it would seem to me that I’d want all the redundancy I could muster. Did it annoy you and the fireman to get the same info over and over and over, or did you see a benefit?
Not too long ago a thead concerned a new Class I hiree who was worried that he might not quickly master his road’s rather complicated signals. Like bridge (which needs only about a 20 words to speak volumes), or bidding at an auction, it’s context that can make a difference. Nobody can learn language (or meta-lang
An obstruction could be another train; standing equipement; improperly line switch or derail; simulated obstruction (ie the “Banner Test”); sometimes washed out track or a tree down. At least in my territory, a train is never permitted into the same block as another train discharging passengers.
However, a landslide or downed tree, unless the track is equipped with slide detectors, will not trip an automatic block signal to red. In addition, unless the “Banner” is equipped with a shunt device, the automatic signal will not trip to red. Usually, in both these cases, the crew will be talked by an absolute signal or be issued an instruction to operate at restricted speed between such and such a milepost.
As for testing crews in this manner. First it’s required by the FRA. Second, it’s a good way to make sure the crews are following the proper procedures. I’ve seen many wrecks, where a crew passed a red (either a permissive or with permission by) and plowed into standing equipment, or ran through an improperly lined switch or derail. If you run over a banner, it’s treated like failing to stop at a stop signal, and you’ll get 30 days on the street.
It seems every signal in my area is a persmissive red, including those along the Northeast Corridor. I have seen NJ Transit commuter trains creep up on other trains at station stops, ready to move in as soon as the train ahead clears the platform. Not sure if I have ever seen an Amtrak train go beyond the red, but that does seem to be standard practice. I have also seen trains stopped dead at the red waiting for the block ahead to clear before moving into the station.
Along the ex-LV (freight only), most signals appear to be permissive reds. The trains don’t stop but just move slowly. The track ahead (e/b) is a straightaway for miles. One reason for the permissive reds I think is the number of grade crossings. A stopped train, if long enough (100+ cars), could tie up motor vehicle road traffic for miles in just a few minutes. Even slow moving freights through a grade crossing cause large traffic jams. This could hamper emergency vehicles (police, fire, ambulance) from getting into certain areas.
Absolute reds occur at merge points – where two tracks merge into one. I’ve seen w/b traffic stacked up – one behind the other – on track 2 waiting for e/b traffic to clear the single line. It appears that e/b traffic is always superior on the LV single track.
That single track between Bound Brook, NJ, and Potter (North Edison), NJ, will soon be history. Grading has already started for a second mainline track, foundations for new signal towers are in place, and new electrical boxes for crossin
There are two general types of Red Signals - Permissive and Absolute.
Absolute signals, generally, are controlled by a control operator (dispatcher or interlocking operator). They can make the signal whatever color they want depending on how things are set up. Absolute signals also can not be passed when “displaying STOP Indication” except under the direction of the control operator and in accord to specific rules or instructions. Normally, they can not be passed at a rate of speed faster than walking - but again, check your rules, timetable and timetable-special instructions and the bullitins thereto. Some situations will permit Restricted Speed.
Automatic signals (ABS) can be passed AFTER the train has come to a complete stop and movement can not exceed Restricted Speed until after the rear of your train has passed the next signal displaying a less restrictive indication - such as flashing red, yellow, green and so on.
Plated signals, whether Absolute or Automatic, display indications for certain conditions that may or may not require a stop but cause the signal to display stop. These usually have a triangle with the letter “P”. Again, see your rules, TT, TT-SI, bullitins, etc. Absolute signals may or may not display a plate (seldom do), but if permissive conditions exist, they will display a flashing red (proceed without stopping, prepared to stop at the next signal, and not exceeding Restricted Speed). This signal may be coded by the control operator or by some protective device such as a slide detector, high water detector, collision detector and so on.
Passenger stations are protected by an Absolute Signal one (at least) trainlength each direction from the depot. Not even God can get another train past that signal when passengers are entraining or detraining.
A “new” “P” or “G” signal indication has started to be used instead of the plates, and that is the flashing re
In Penn Station, two trains on the same track is considered a slow day. This depends on which track one is talking about, however. That place can be like a sardine can full of trains, especially the Long Island and Empire Service tracks on the north side of Penn Station. LI trains will pull as far west as they can on a track, so there will be room for a second train, which got there on a permissive red (stop) signal. The train creeps up behind the one ahead of it to unload. Then, they might couple the trains together and one hostler will clear the track as soon as they have a place to go. This can be rather time consuming, when say, a train needs a brake shoe replaced. Then the supervisors are hovering around like buzzards looking for a meal, or for a car knocker to forget some thing.[:-,]
That is normal every day standard practice at Penn Station in NYC. In fact, if I make my way to track level from other than the main concourse and before the official boarding announcement is made, I have to ask a Trainman where I need to board for my destination. One NJ Transit train may be heading towards the Jersey Shore, another to Trenton on the NEC, and still another to somewhere else. See map at http://www.njtransit.com/images/railmap06.jpg for all the possibilities.
I have not seen more than three NJ Transit trains stacked on one track. Separation between the trains is about two feet, if that. It certainly gives you an idea of just how big Penn Station is at track level, and that capacity was largely built back in the 1930s.
However, the situation I was relating occurred at another NEC station, where two trains at the station is physically impossible (except for Newark, NJ). One train is in the station, discharging and receiving passengers, while another sits 100 yards behind, well past its red signal, waiting to move in to the station as soon as the train ahead pulls out.
At Newark, tracks are numbered A, 1, 2 (e/b), 3 (e/b or w/b) and 4 and 5 (w/b), not including the two Port Authority Trans-Hudson (PATH) tracks. Track 5 is normally reserved for the diesel-powered Raritan Valley Line. At evening rush hour, as one train approaches departure time, there is normally the next train scheduled already nosing into the station. The same also holds true for trains on tracks 3 and 4, but there the separation is about 200 yards minimum.
To complete the picture at Penn Station Newark, immediately east of the station is an immense multi-span drawbridge over the Passaic River, the scene of at least one deadly accident, where a train plunged head firs
On the CN Waukesha Sub, Absolute signals do not have a number plate. The only time you can go past a red is if you get talked by.
Permissive signals have a number plate. Red signal can be passed as long as you do not exceed restricted speed. Usually there is a guy in the block ahead, so don’t hit him.
A restricting aspect is either a flashing red or lunar (white). Searchlight signals seem not to flash, so the lunar is used.
