So, I’ve begun looking at a U-shaped 5’x9’ HO layout. I’m finally getting close to running trains again! However, I’ve come across a bit of a roadblock.
The original trackplan calls for a soda bottling company, a cardboard box company, a small intermodal yard and a fruit packaging company. Well, I don’t have the time or creativity to search around for buildings or rolling stock to fit these. I do, however, have an ADM grain silo (fully built by yours truly), a feed and seed (again built by me) and several other rural buildings. I’m trying to figure out what else I’ll need. For simplicity, I have some modern oil tankers, hoppers, bulk flatheads and a flatcar, gondola and about five or so boxcars. Along with these, I managed to acquire two passenger cars, but that’s for a future expansion. I’m trying to figure out some more industries I can manage to squeeze in here (I can probably fit about four or three), and came up with the idea of adding an oil loading station and oil tank, a small finished lumber company and the two buildings I described above. I’ll get the original trackplan up when my camera decides to start working again and hopefully that will give yall a clearer idea of what I’m trying to accomplish here.
Also, the benchwork…this will be a doozy. I’ll be attempting to build domino style benchwork, detailed in the 1999 edition of Model Railroad Planning. There’s three main dominoes, but the problem is I have no idea on how to build these. I was wondering if anyone had any experience building these and had any tips or tricks to speed up construction.
Sounds like Linda Sand’s plan from MRP 1999. It’s a good plan.
Okay.
A standard industry for small switching layouts is a warehouse or food processing plant with several doors. Gives you several industries for the price of one - you can decide that some loads (say refrigerated goods) needs to be unloaded at door 3, some loads (say beverages) at door 2, and some loads (say canned goods) needs to be unloaded at door 1. And then you have three indystries.
Another popular type of track is a team track/transload track. Where you can leave any kind of car - and the customer will show up with a truck of some kind (flatbed, enclosed, tank truck or whatever), to unload the car. The same track can be used for delivering lumber, tank cars of chemicals, covered hoppers of
With camera, MRP 1999, Walther’s catalog and rulers in hand, I ventured into the dark depths of the basement to measure out and get a rough idea of what I can realistically fit on the two dominoes.
Upper right domino, used to hold the intermodal and plastics factory, now has my ADM silo and a planned lumber co. I believe I can fit both ends of the Walton & Sons Co. side-by-side, with the office somewhere closer to the edge of the aisle. Along with a bit of modifying, I can fit the ADM silo…nobody needed that goofy truck access anyway.
Upper left domino, housing the feed and seed and eventually the oil loading platform. If I were feeling adventurous I’d add a fifth industry, but I honestly don’t know if I can fit anything other than a small warehouse I inherited from a friend of mine after he moved on to HOn3. You can just barely spot it and a German trailer in the background of this next shot, detailing the right domino a bit more.
A basic box frame is all you need. My modules are 7 ft by 18 inches. I used 1x3 furring strips mostly. So I built an outside frame, glued and screwed together, and added two other braces cross-wise equally spaced. This makes four box-like sections. Then I added Luan for the top, glued and nailed. On top of that I glued down a one inch sheet of foam.
Alright, I think I have the general idea down in terms of benchwork. Now, this is probably one that’s going to cause me more headaches than anything…how would I wire all of this for DCC? I’m hoping to somehow convert most (if not all) of my locos to DCC.
My benchwork is dominos. As a previous poster said, it’s basically a box with a top. I used 1X4 lumber for the frame. If you have a table saw, some people recommend cutting 4" strips from 3/4" plywood as it’s straighter and more stable than dimensional lumber, but it doesn’t hold screws or nails too well in the end grain. I was fortunate to get nice straight pieces shopping at a “real” lumber store, not a big box store. My sections are 2’ wide and 4’ or 6’ or 8’ long, depending on what was needed to fill the area. I glued and screwed the lumber together, and put the short end pieces the full 2’ width to make better mating surfaces when they are joined together. The long sides, of course, have to be shortened by 2X the thickness of the wood. I glued and screwed short pieces of 2X2 in the corners for bracing. I used a framing square to make sure the frame was square before leaving the glue to dry. I put a 1X4 brace across the centre of the 6’ section and two braces across the 8’ section, 1/3 of the way in from the ends. Before installing the braces, I drilled 3 large holes in each one for the wires to pass through.
I topped it with 3/8" plywood, glued and nailed down. Then I painted the entire underside white. This protects the wood from moisture and also makes it easier to see the wiring and the terminal strips, etc. when I’m working underneath the layout. I painted the edges brown, but you can use your favourite colour. I glued 2" foam to the top of the plywood, but that’s optional. Not every one likes foam or even 2" of it.
For legs, I just used 2X2s bolted in from the long sides up against the 2X2 braces in the corner. There are many other ways to make legs. I suppose on the 8’ domino they should be in from the corner but it seems stable enough. I used bolts so that the legs can be removed for the day when it will have to be moved out of the house. I drilled holes in the bot
I guess what I’m asking is less method and more explaining to a newbie how it should commonly be done. The only experience I have with wiring a model railroad was using a terminal track. Is that basically the same idea here? And I’ve heard a lot about dividing power along the railroad and making “power subdivisions”. What do all these mean?
Hollow Core doors from Home Depot or similar source are perfect bases for a domino-style layout. They have ones that are primed and plain with no cutouts for locks or hinges, in widths from 24 to 36 inches and a length of 80 inches.
Wiring for DCC is pretty simple, especially for a smaller layout. Run two wires under the layout - one from each terminal on the controller. Call them e.g. “near” and “far”, or “red” and “green” or something like that (they won’t be “plus” and “minus”, since you have alternating current with square pulses rather than DC on the track). Wire feeder wires from this “bus” to the tracks. Done.
You do not need power districts. Power districts are for larger layouts where you want to have circuit breakers located so that power only goes off for part of the layout in case of derailments causing shorts, instead of the power going out for the whole layout (DCC is more current than DC, so you want to cut power when there is a short, so you don’t cause stuff to melt from the heat). If you have a layout with 10 people operating, it is nice that things doesn’t stop for everyone when one derails.
The other use of power districts is if you have lots of engines running at the same time, so they together pull more current than is delivered by the main power supply/command station - in that case you can have “boosters” delivering power to other power districts - say having a larger engine terminal being it’s own power district.
Neither of these are likely to be true for a small layout.
Another thing about DCC is that things happens faster. On DC a passing short might cause a brief arc, and then the train continues. On DCC power will go out and everything stops. So some turnouts may need some rework, if they are liable to cause brief shorts. Or you can just buy DCC friendly turnouts and go with that.
