I am looking for an accessory transformer and need advice. I had purchased a Lionel 1.8 amp unit but am not satisfied as I feel I will end up with more accessories than it will handle. In fact, I already have.
Looking for a unit that will handle four(4) 022 switches, 8- 10 streetlights, 2 or 3 signal blocks, 3 or 4 illuminated buildings and 3 or 4 other things I “ain’t” thought up yet.
Want something basic and simple and reasonably priced.
The problem with the 14 volt range on a KW is that it can’t be used with the commons for switches(or other accessories) on the track. Unless the KW is dedicated for two fixed(6 volts and 20 volts) and two variable accessory outputs(A-U & B-U), it’s not very versatile for accessory use.
Ok….let me take a shot at your question. At present my 4 switches are connected to a 1.8 amp Lionel accessory transformer and I am using the outside rail for the negative.
All other accessories are connected to the KW’s 14 volt taps.
YES on phasing. Common is U. I use the variable side of the KW’s and set the voltages at the best operating voltage. ZW’s phased with these for track voltages. All transformers I used are phased together. I use about 14V for switches. Makes them open and close fast and especially those working together.
My gut reaction was to say to use a 1033. Hook up the accessory on which ever of the variable taps will give you the needed voltage. On a couple of temporary layouts, I have used a CW80 to power the accessories. This was paired with a brick or another CW80. It has been my experience that the CW80 does not really play well with other modern control components like a TPC300/400 and Legacy combination. Good luck.
I’ll say it again: Accessory voltages do not have to be in phase with track voltage. In fact, there can be slightly less voltage drop if they are out of phase with the track. It is also true that the accessory voltage does not have to have the same voltage, frequency, or waveform as the track voltage. For example, my turnouts operate perfectly well on DC capacitive-discharge sources.
Consider the three utilization-voltage wires coming into your house: They connect to a center-tapped 240-volt transformer secondary somewhere outside. There’s 120 volts between each of the black or red wire and the white wire, the neutral, which connects to the center tap. Half of the 120-volt outlets in the house are fed from black and half from red, 180 degrees out of phase with each other. Any currents drawn from black or red and returning to white are also out of phase and cancel in the white wire. The worst case, that you are drawing all your current from one or the other of black and red, is that the current in the white wire is the same as the current drawn from the other wire. So the white wire doesn’t have to be any bigger than the other two.
Furthermore, if you are drawing some current from each phase–almost always the case–the voltage drop in the white wire is less than than in the other two, because the return currents cancel. This is the main advantage that we can exploit on train layouts, by using the outside rails as the common return for both train and accessory currents, out of phase with each other.
If we used the simpler, two-wire, circuit that many other countries have, it would actually require about 67 percent more copper than the three-wire circuit to deliver the same power at 120 volts. And we wouldn’t have the voltage-drop improvement as a side effect. (They get away with two wires because they generally have almost twice the utilization voltage tha
