Advice on improving Athearn RS-3 electrical pickup
Guy’s,
I am adding a LokSound to my Athearn RTR RS-3. This loco will stop and lose sound over some track spots (Clean) and over my DCC friendly Walther’s number 6 turn outs. What have you done to improve this pick up? My ATLAS units do not stall here at the same spots. It is discouraging.
Thanks, Chris
Hmm…the RS3 should have decent pickup out of the box.
OK. Take the shell off and then remove the clip that supplies power to the top of the motor.
Remove the trucks buy prying off the worm gear clips. Check to see that the underside of the frame (where the frame rides on the truck) isnt still painted or gunked up. Check to see that the trucks are free rolling and the wheels are in gauge.
Replace the trucks. Solder a wire from the top of the T clips to the top of the motor (effectively replacing the metal clip…).
Beyond that, I cant help…
David B
I have two of the Athearn rtr locos and they both suffer from pick-up issues. My two best recommendations would be to tear the trucks down and clean them really good or replace them with new replacements.
David and Jeffrey,
Thanks for the input, I may consider NWSL wheels and axles as well.
Chris
Good luck with it. Athearns are simple machines with lots of interchangable parts. I personally repower mine with Kato motors.
David B
I have found that most electrical pickups and contacts are dry, and when they are, it causes these types of intermittent pick-up problems. What I am going to recommend may sound crazy, but you may want to try it before you do anything drastic. I am a retired electronics technician, and when working with barrier type terminal strips at my former job, we used to spray them once a year with a silicon compound similar to WD-40. What I have learned from this is that a very light weight silicone oil actually improves electrical contact. So, on my loco pickups, I apply a very small amount of WD-40. Don’t spray it directly from the can on your loco. Spray some in a small plastic cup, then pick up some with a small metal or plastic pick of some sort and apply it to the areas that are used for transmitting the electrical current. For instance, I apply my standard light weight loco oil to the wheel bearings, then apply the WD-40 to the outside of the bearing blocks where they sit in the metal frame. I also apply some to the rails after I clean them and the loco wheels. I dip the end of my finger into the WD-40 and rub it on the tops of the rails for about a foot. I then run my loco through it and around the layout. This application is similar to using Rail-Zip, but without the big mess that usually results from constant use. In my trains, I try and run at least one boxcar that has a masonite track wiper pad. This is a perpetual track cleaning process. When the pad gets dirty, I sand it off with a medium grit sandpaper, blow off the resulting dust and put it back on the track. I repeat this WD-40 application process only when I clean my loco wheels and track with either a bright-boy or cleaning chemicals.
Elmer.
Chris – while I don’t have this loco, I have observed some interesting interplay of walthers dcc friendly turnouts at the frogs and diesel engine 3 axle trucks (such as the atlas RSD 4/5). The one wheel set that floats (ie non geared) has enough ‘slop’ in it to cause intermittent shorting at some frogs. I have found that flangeway depth and flangeway width’s at the problem turnouts had to be adjusted carefully - mostly shimming was needed in the frog to get consistent flangeway depths through the frog. I had to run locos very slowly through the problem areas and get my eyes at the wheel level to see what going on.
Also, using a very light application (1 drop) of conductive lubricant on any contact surface on the engine helps as well.
Charles
elmer great advice I am going to do that to my locos tomorrow!!
How old is this loco? You do state RTR, not BB.
I have a RTR RS3 also. After installing a decoder and sound, it ran pretty well for a while, then I started noticing the sound cutting out and the loco hesitating through some turnouts.
The RTR I have has 2 wires coming from each truck. I happened to notice that one of them had BROKEN where it was attached to the terminal on the truck. Actually, I ended up fixing both trucks, when I checked the second one and barely touched the wire, it broke right off. Fixed the wires, problem solved.
I have 2 RTRs, the RS3 and a Tunnel motor. Both run fine. I could understand if this was an older BB loco where you might need to tear the trucks apart and clean everthing and maybe change wheelsets, but a newer RTR?
Not really surprising. The rtr line are basically BB locos with more details and soldered contacts on the trucks instead of the contact strip and frame grounded motor. Most of the truck assembly is the same. How do I know? I a rtr AC4400 that has bad pick-up issues. I’m going to have to replace the front truck completely.
