AF Switch - Cars Uncoupling
As I make progress rehabbing my old American Flyer trains, I have set up my remote control switches as part of the mainline. Some of the freight cars have been uncoupling as they pass over the switches.
I can see why. The bottom of the couplers are striking the outer switch points and opening up the knuckle.
Primarily, this occurs on the cars where I have converted the old link couplers to knuckle couplers. I have “bent” the arm upwards that holds the coupler, but the bottom of the coupler still grazes the switch point and opens the knuckle.
Would it be a mistake to slightly file down the switch point to assure clearance with the bottom of the coupler? Or, is there something else that can be done other than trying to lift the coupler arm any higher which may not be possible?
Thanks.
What would you think about using a Dremel to file a little bit off the bottom of the weight?
Rather than grinding off the weight, bend the whole coupler slightly up. This is real easy on link to knuckle converts. A good starting point is to bend the coupler till the bottom of the coupler is about 3/16" clearance at switches and rerailers. Also make sure the track to switch transition is flat. They will work. Don’t damage the coupler.
Jim
Jim,
You are right. I will continue to adjust the coupler heights rather than grind or file the weights. It is primarily a problem on the cars where I converted the old link couplers to knuckle couplers. A little patience is undoubtedly what is required here.
I did try it, that is true, and it improved the clearance, but not entirely. I am going to experiment a little more with the bending idea and then consider whether to grind down the weight. I have managed to reduce the number of occurrences (i.e., uncoupling), but I have not managed to eliminate the problem entirely.
Don’t abandon me. I am willing to try any and all suggestions.
OK, I got your meaning. It makes sense. I will study the matter a little more.
I have had both link and original and converted couplers that despite repeated adjustments continue to uncouple. I have used with success these methods and it does not damage any parts.
Link Coupler – Take the small rubber bands like used on teeth braces or small ponytail bands, and wrap it around the coupler. A small hook fashioned out of a paper clip helps.
Knuckle Couplers – take a small piece of cardboard and with the coupler in the closed position and the weight in the down position, wedge the card board between the weight and the bottom of the coupler to prevent upward travel and release of the coupler. I’ve also used several wraps of string for the same effect.
Jim
Jim,
I would be good with that approach, but either method that you describe will preclude you from uncoupling the cars if and when you actually want to, correct?
