post deleted
If you want to fix them up check the proto 1000 shell to see if the pilot is separate on it and could be mounted in the AHM. Then I would check E bay again for shells for the AHM. Beyond that you are probably on your own and should probably consider making a mold of the one and casting the others in epoxy.
I don’t mean to sound rude, but why would you want to mess with a AHM FB when P1Ks is competely scale, runs 50 times better, has body mounted couplers, handrails, and scale flanges on the wheels? Also you get them on eBay for $25.00 to $35 dollars. Just wondering? No flames please.
