I read that part as a warning that doing the test with the locomotive handbrakes applied may lead the employee doing the test to incorrectly assume the cars are secure…It may just be the way I am interpreting it
On my carrier, locomotive handbrakes are not to be used to help secure a train, only the handbrakes on the cars, for the simple reason we may, at some time during the day, need to remove the locomotives from that train for use elsewhere.
We are required by general order to apply handbrakes to cars, and then release all the brakes on the locomotive and let the weight of the locomotives try and move the cars…if it remains in place, good test, secure the locomotives and leave it, if the cars move more hand brakes should be applied, repeat as needed until train is secure.
We also do a push/pull test, if the locomotive under power has a difficult time moving the cars with only the cars handbrakes applied, it is reasonable to assume the cars are secured and can, if needed, be left unattended.
We are also required, when cutting away from cars, to “observe for a sufficient amount of time the cut of cars to be left and verify that no unintended movement occurs”
This rule allows us to cover the portion of the GCOR that refers to cars left unattended also…because the cars alone are providing the retarding force, they meet the criteria for both leaving a train unattended and a “cut of cars” unattended.
I would assume most carriers do the same thing.
Not picking a fight, but the reasoning in your last two sentences may be the major contributing factor to this event.
If the handbrakes on the cars had been sufficient to hold the entire train, including the “dead weight” of the locomotives, then nothing that was done to the locomotives afterward would have cause the train to runaway.
