Air brush woes
I’m sure this has been covered in the past but a search for “Badger 350” gave 0 results and a search for “Badger air brush” yeilded results but no threads per se.
I am new to acrylics but not to airbrushing.Years ago, I had a Binks Wren that I used quite successfully. When I bought the 350, I thought I was getting essentially the same brush. Not so. The Binks nozzles had a replaceable “o” ring that prevented air leaks as well as providing friction so the paint volume would remain as initially set. The nozzle also threaded into the brush body and remained tight. The teflon hose that is in the paint container lid, refuses to stay in the brush body and falls out mid way.[8o|] The Binks air button had a adjustment wheel to control the amount of air without going back to the regulator. The 350 is either on or off.
Have there been any solutions to these areas?
Why did my paint bubble up into the air hole in the top of the paint bottle?[*-)]
The ar stream creates a lower pressure over the nozzle causing the paint to rise up the tube Bubbles iindicate that downstream is a blockage causiing te air to divert down te paint siphon tube. The air ma be blowing the tube off.
