Alco PA head lights
Can somebody help out with what lights were fitted to SP Pa1’s. Top was ???
Bottom light was ???
Also rear lighting for Curved end passenger cars.
As I am tring to light a Daylight Passenger train
Regards Sandee
Sandee–
There are lots of SP fans out here, many of whom are better informed than I am, but I’ll get you a start. I suspect you’ll get more authoritative answers from others.
The upper headlight on PA and other cab-type diesels was an oscillating white light.
The lower light was the principal headlight, which could be illuminated on a “bright” or “dim” setting. (Note that the PA1s of SP subsidiary Cotton Belt, No. 300 and 301–later SP No. 6067 and 6068–had only a single headlight, in the upper location.)
SP observation cars originally were equipped with built-in marker lights on the sides of the cars, and a single, large light at the rear centerline. I can’t tell from photos alone whether this was strictly a red light, or whether it was also capable of white illumination (to serve as a back-up light for reverse moves). (See also the discussion of observation car lights elsewhere in the forum.)
Around 1959 the observation cars were modified, with removal of the side-mounted marker lights, and installation of a 5-light “array” on the rear of the cars above the rear door. A large oscillating red light, on the car’s centerline, was at the center of the “array.” Pairs of smaller marker lights were mounted on either side of this light, with the 2 green lights at the top positions, and 2 red lights at the lower positions.
Hope this helps.
–John
Thanks John for info you have given me a start now all I have to do is start to work out how I will pull it all together.
Sandee
