I’m looking at picking up an undecorated Atlas RS-1. From the few photos that I can find of NYC RS-1s, they appear to have roller bearing trucks. Can someone confirm that for me? Atlas offers undecorated RS-1s with either friction bearing or rolling bearing trucks.
The undec Atlas RS1.S. I got had a packet in it. This had caps to either make it friction or roller bearing. These are the just released version. Not sure if they do that for older releases
Yes, the newest release comes with both sets of trucks. Maybe the eBay seller (who had two) decided to outfit each with specific trucks to make them more “sellable”?
Roller Bearings or as I call them “spinning triangles” started appearing on locomotives and rolling stock in the later half of the 1950’s. By 1963, virtually all cars and diesels were equipped with them.
I seem to recall reading somewhere that it was the Timken sales people that liked to use the term “friction” to describe those old-fashioned, plain, solid bearings.
In reality, reducing that friction, especially when the train was standing with no oil film between the babbitt and the journal, and even worse in cold weather, was a big advantage to the railroads. Longer trains with less TE and fuel.
“Taking Slack” was sometimes the only way to get a stubborn train moving and that would sometimes lead to busted knuckles and pulled drawbars.
Then there was the reduced risk of hot-boxes, the greatly reduced labor for checking and filling journal boxes and the labor for changing out the brass and the economic advantages of “Roller Freight” became obvious.
Seems this term is pretty much railroad-only. Be interesting if it was marketing by Timken. I mean, “friction bearing” would be a brake, not a bearing. “Solid bearing” is the more proper mechanical term for the old journals, adn they did have friction reducing material lining them and then lubricated with oil - the waste packing was used to keep oil IN the journal and not just flow out through the mostly non-existent oil seals and onto the ground. Run out of oil and then you have metal on metal getting hot - hot enough to deform the bearing surface and cause an axle to fall out with catastrophic results, or hopefully produce enough smoke from smolding oily waste that someone in the crew or trackside would spot it and stop the train before anything worse happened.
Also, many early roller bearing diesel and passenger cars had covers over that rotating axle end cap. Today those covers are banned by most railroads. The rotating end must be visible unless there is a speed recorder drive on it such as on a diesel
Be advised the ‘rolling triangle’ bearings are grease-lubricated. The version Ed’s reference called out was oil-lubricated, which required a fixed side cover.
Comparatively very recently, CSX stopped allowing Hyatt bearings in interchange. This came as something of a puzzler until it was recognized that these bearings require a fixed cover to run.
I had pointed that out but must have neen “lost in translation”
Grease packed, sealed bearings will have “NFL” stenciled somewhere on the car.
Not Field Lubricated.
Some of the private (passenger) car owners have faced great expense to rebuild their trucks with new bearing packages. In some cases over $1500 per bearing for reconditioned roller bearings (x12 if you have three-axle trucks!).
