Hi. I’ve tried to make this request for help as concise as my limited technical/electrical knowledge will allow. My buddy will come over tomorrow (Tues.) to help and bring some spare gear/cables to swap out. So I may not be able to respond with any conviction until then.
He did think it might be the Command Station that’s malfunctioning but all lights seem correct. He pulled some wires from the C.S. hookups and thinks he isolated it but we’ll confirm that when he swaps out with his gear.
Here goes. Thanks for your help!
I have a Super Chief Digitrax system using DT400R throttle.
I have been running without issues for a long time but suddenly, I’m experiencing short circuit indicators on my PSX s and it shuts down BOTH the main and yard. They are on separate busses and power districts are in place via gaps in the tracks.
I’ve trouble shot the layout wiring (and don’t think that’s the issue anyway-all recent, new installation but in use for months to 2 yrs. depending on the section. The only NEW addition was an AR PSX board for a wye. The wye is hand thrown for now so no switch motor involved.
Here are the behaviors I and fellow troubleshooters have seen:
.01 I have three separate power districts. The main yard and the mainline are separately bused (bussed) but there is an additional industrial yard that is only fed via a feeder from the mainlline as we’re about to install that buss. Everything previously seemed to get enough current prior to these problems:
l. For a couple of hours of troubleshooting, the whole layout would shut down and show a short on the PSXs. It would re-set and come back on after about 4 min. or so. AFTER about 2 hrs. the system (track power) would shout down (show a short) and NOT come back on after the 4 min. That’s when we ceased and desisted.
It does not seem to be a thermal issue with the command station. Nothing is hot or even warm and this has not been a past issue.</
