They people here who have doodlebugs by spectrum
How do u take the sheel offf the doodlebug
Thanx [8D]
Not an easy task!! I took a small screwdriver and went down the side(under) and seperated it carefuly,(pushing the sides outward) it catches on tabs that are on the chassie, then work it out little by little. It’ll take some time but it does come apart. you’ll need to be very careful putting it back together.
tthanx
For a more detailed explanation, please see “Merry Christmas! Spectrum HO Doodlebug review”.[:D][:D]
Depending on what you are doing, the roof will pop off if you take a very small screwdriver and CAREFULLY twist it so the top moves away from the tabs. This will allow you to install a decoder,change bulbs, etc.
