Am i asking to much of the PW ZW 275wats
I have a post war zw 275 WATTS i run that though a lionel lock on circut breaker to a tpc 300. Last night i was running a pensy T 1 with 7 lighted cars For some reason the fuse got hot and blew not the house lock on wont energize the solenoid. Could the house have been going bad? I ran the same trian on a diffrent line no problems yet. Is it to much for a ZW to run 3 trains?
What does this mean? “For some reason the fuse got hot and blew not the house lock on wont energize the solenoid.”
bob I’m thinking hes talking about the lock on lionel has that looks like a shed
now just for info for you I have a post war ZW, I run with no problem 2 dual motor engines, one single motor engine ( this one is a pul-mor) 5 passenger cars all lighted, and 2 caboose lighted on basically a 8’ X 14’ layout. I use direct wiring to the track with surge protection at each feed to the track. I have also done this with one track being hooked up to a tpc-300 to one of the tracks with no problem.
I must agree I am not sure what this is. ““For some reason the fuse got hot and blew not the house lock on wont energize the solenoid.””
With my PW ZW I can run two Lionel duel pulmor motor Dash 8s a Lionel 1666 and a burro crane all at the same time with no problems. I have install 10 amp quick reseting breakers in line behing the transformer and have no problems.
I am thinking you must have something shorting out.
I think there was a typo there.
He probably meant now and typed “not”.
A ZW should be able to handle 2 long lighted passenger trains. 3 is pushing it.
