I’m slowly assembling my American Model Builders (AMB) wood caboose kit and it’s coming along nicely:
[Sorry for the lower quality pics [:$] Low light with cell phone camera.]
The interior shell I scratch-built using .020 x .040 (#2040) V-groove sheeting and it is entirely removable. I was hoping to NOT have to use bracing. However, the thin walls warped inward slightly once I applied the Plastruct Plastic Weld to the seams (not a real surprise) so I straightened the walls out using 6 x 6 dimensional styrene, as seen above.
Yes, perhaps overkill for something that won’t really get noticed from the outside but I enjoyed making it, nonetheless. Those seams won’t be coming apart though - that’s for sure! [:D]
Anyhow, what I’m wondering is when would be the best point to decal it the exterior?
The assembly instructions are quite detailed and suggest painting the parts prior to assembly, which I have done. However, there is no mention when exactly to apply the decals. It would seem logical - at least to me - to do it after the wood side panels have been pressed onto the frame but prior to installing the window glazing.
While I don’t want the gloss coat then dull coat to ru
That’s what I think I’d do, Tom, though I have been known to dither while overthinking things, when it comes to that point in the assembly.
I’d suggest that the Dullcoat should protect the decals while you fit the windows and extra details but then again, the Bear has been known to get that wrong as well!!!
Good luck and have Fun.
Thanks, Bear. That makes sense that the gloss & dull coats would protect the decals after they are applied. I’ll mull it over (over-think it) some more. [;)]
My intention is to give the car a thin brush painted coat of NYC mineral red then apply dry transfers from CDS lettering.
Presently the car is painted in Krylon red oxide primer. You can see the relief of the wood grain in the above view and I’m afraid even the best quality decal job will still show the film.
I have high hopes that the CDS dry transfers will go on nicely and look convincing. I hope to tackle this job in the next few weeks.
Just one quick observation, if I may. I tend to think that some of us “beat” ourselves up over such matters, while posting incriminating close up photos of stuff that wouldn’t be noticed if the 3 foot rule was in force!!
No criticism intend. Did your AMB wood caboose kit come with the thin, add-on door frame around the door opening like the windows? It looks nice - especially with the door inset like it is. Mine did come with a door frame and sill and I applied it; that’s why I’m asking.
I’ll look forward to seeing how the dry transfers look when you get around to applying them, Ed. [:D]
I used multiple coats of MM gloss and my decals went on OK. I am not at home but will take a pic next week.
Went to Photobucket to see a close up of your railings. Got 4 popup ads, but what did you use for railings, mine came with a bunch of wire? I have not made railings before, so I stalled out.
I’m a big fan of C-D-S dry transfers, although the ones I need are difficult to find. Up until very recently, all of my custom lettering, three different orders, were from them.
After you apply the lettering, burnish it very thoroughly, then use a new #11 blade or a new razor blade to slit the lettering at all board separation grooves, then apply Solvaset. It should make the lettering settle into the grooves just as it would with a decal, although you may need to make several applications.
This also works when using dry transfers on plastic models of wooden cars, although it’s seldom necessary to pre-slit the lettering, as board separations on plastic models are less pronounced than those on wood.
Pretty-well all of my almost 400 home road cars were lettered with dry transfers, and perhaps 80% of my interchange cars, too.
Sorry, Tom, I forgot to include that in my earlier reply. Definitely apply the lettering, and all the prep work for it and the clear overcoats to protect it before adding the glazing.
I usually apply the glazing on passenger cars as the very last step, and on cabooses, locomotives, and windowed-MoW cars as the second-to-last step, just before weathering.
Glazing last, because any of the prep work you need to do foor decals will ruin the glazing material - Dullcote, Glosscote, decal setting solution - it will make a mess of the clear windows because no matter how careful you are, some will get on them - and that’s a whole lot of masking you’d need to do before spraying anything. Also when applying the dull finish, you want it on all the window frames tooo, so you don’t have a nice dull car side with these shiny window frames (unless they are metal replacements on the old wood car or something).
On a car with separate sides / ends, I prefer to do as much as possible ‘up front’ while the parts are separate and ‘flat’. I’d paint the sides and ends (inside and out), seal with gloss finish, apply decals, then Solvaset to snuggle them down. Then, on a wood car or building, I take a single-edge razor blade and trace down each opening between the boards, then reapply Solvaset (perhaps several coats as needed.) Then seal in the decals with flat finish, weather with powdered charcoal, and then seal that in with flat finish.
With that all done, you can add the window glazing before assembly, and not have to worry about ruining them. Generally, when the car is all done, I’ll add some weathering with powders / chalks.
