My Brother recently purchased an American Flyer Frontiersman Franklin 88 locomotive, it s only missing the stack and bell. I took the body shell off and was puzzled, was this locomotive equipped with choo choo and does this locomotive use the same motor as the 4-4-2 Atlantic?
It does have smoke and choo choo. Except the unit is from the HO line so it is rather soft sounding. The motor is like all late style Gilbert motors in that it has the motor armature that is cicular instead of the flat early style. They also came with the two position reverse unit. Keep your wheels and track clean otherwise the locomotive will go into spasms. Replacement parts can be had from port line hobbies
This dealer’s website carries assembly and wiring diagrams for all AF locomotives. This should help you identify what parts you may be missing.
all its missing is the stack and bell
that makes sense, when it runs, their is a soft choo choo sound.
here are some pictures
